Old 04-22-2005, 09:00 AM
Sandro's 1969 502 Camaro's Avatar
Sandro's 1969 502 Camaro Sandro's 1969 502 Camaro is offline
These rims r actually lui's with the red 68. I liked them so much I sold my wheels and ordered a set. The only problem is now I have no wheels . the tires I'm running r 285/30r20 and 245/30r20 or 225/30r20, Lui went with 225/30r20 in the front. his car looks awsome. The offsets I went with were 6" in the back and 5 1/8" inthe front. One of the resons I went with these rims is that when I installed drop spindles on my car it ended up putting my tie rod ends to close to my wheels, so I had to run wheel spacers. Now with the 20's it clears my tie rod end completey and in the rear my new rims r an inch wider than my old ones. every inch count's
Old 04-22-2005, 06:00 PM
GEORGE SANCHEZ GEORGE SANCHEZ is offline
Default Hey Sandro Just Wonderin?
Just Wonderin On Your Smoothies What Sizes Did You Use I Loved That Look I Have Your Car As My Screen Saver .did You Use A Shortened Rearend ,or If It Was Stock What Offsets Did You Use ?
Tire And Wheel Combination Did You Use?
I Wish I Would Have Bought Them Please Help Me Out With The Info Thank You
JUSTACOUPE
Old 04-22-2005, 11:04 PM
I was running a 20x8.5 with 5 1/4" b/s and 285/30R20 tire. My rear end is a 12 bolt housing that was built to stock width, but I'm running big ford bearings (no c-clips). The leafs are globle west cat 5's dearcked about 2 1/4 inches. I think a total of just over 3.5" inches.
In the front a 18x8 with 5" b/s and 235/40R18. On the fornt I run 2" dropped spindles and QA1 adjustable coil overs. After installing the dropped spindles I had to run a 1/4" spacer for clearence between the tire and tie-rod end.
If your going to order rims I would just use this as a reference. I've probely let about 3 or 4 other people try my rims on their cars (all camaro's 68,69's mostly stock) and they never fit the same way on each car..
Old 04-24-2005, 01:14 PM
Default thanks
thanks for the info it will come in really handy
JUSTACOUPE
Old 04-30-2005, 08:24 PM
tndude tndude is offline
Default New Wheels
So Sandro, did your new wheels show up yet?
Show us that ride!!!!
Old 04-30-2005, 09:11 PM
Still waiting, probably be here May 30ish..
Old 05-03-2005, 05:13 PM
ViperBlue68's Avatar
ViperBlue68 ViperBlue68 is offline
Location: Yuba City, CA (about 1/2 hour North of Sacramento)
I had issues with my drop spindals as well I had a 18x8 with 5" b.s. and it rubbed the tie rod end... changed to the 4 & 1/2" b.s. and it fits fine...woulda never used the drop spindals in the first place had i known it....
J.T.
Old 05-31-2005, 12:05 PM
Do you have wheels yet?
