Old 05-20-2007, 09:20 AM
67SuperSnake's Avatar
67SuperSnake 67SuperSnake is offline
Originally Posted by XcYZ
Looks like a great car, but you need to invest in a digital camera.
I have more digital pictures than has presents!
Want to see the build from beginning till now? Or just the "Readers Digest" version?
Richard
67 Super Snake
427FE Vortech T Trim S/C Fast EFI
TKO600 Trans
Eleanor Registry
Old 05-20-2007, 11:49 AM
crc crc is offline
Very nice! Please keep the pics coming.
Old 05-20-2007, 12:35 PM
Got the car stripped down to nothing. Cut out the inner fender wells, rear lower vent scoops, side exhaust holes through the rocker panels, and welded in a brake vent tube. Then I sent off to the media blaster on April 10th, 2006. Supposedly done in 3-5 days.
Richard
67 Super Snake
TKO600 Trans
Eleanor Registry
Old 05-20-2007, 12:39 PM
Default Back from the media blaster
Got it back from the media blaster on May 9th. Nothing but virgin metal:
After much thought, I decided to go ahead and epoxy primer everything. No sense in having to remove all the rust again. Plus I feel like I have gotten somewhere
Richard
67 Super Snake
TKO600 Trans
Eleanor Registry
Old 05-20-2007, 12:44 PM
Default Metal Work
I removed these old floor supports and torque boxes:
Fabbed up some frame extensions:
And covered them with new floor supports:
I replaced the old torque boxes with new ones:
Richard
67 Super Snake
TKO600 Trans
Eleanor Registry
Old 05-20-2007, 12:49 PM
Default More Metal Work
Strengthened the lower shock towers that can be a problem on these old Mustangs:
Min tubbed the rear all the way to the frame rails. Not going to be using leaf springs on this car:
Roll bar:
Floor pans:
Shock tower conduit:
Richard
67 Super Snake
TKO600 Trans
Eleanor Registry
Old 05-20-2007, 12:53 PM
I installed the clutch/brake pedal roller bearing assembly.
I fitted the Brake/Clutch pedal backing plate.
I also installed the Shelby Pedals.
Welded up the original tail panel gas cap hole:
Richard
67 Super Snake
TKO600 Trans
Eleanor Registry
Old 05-20-2007, 12:56 PM
I installed the Rick's Automotive 22 gal fuel cell, trunk hinges, trunk lock, bumper and rear valence.
Richard
67 Super Snake
TKO600 Trans
Eleanor Registry
Old 05-20-2007, 01:00 PM
Got the coilover rear end home.
After carefully measuring I tack welded it in to place. Loosened all the bolts, measured again, and then finished the welding. I also installed side mounting plates to give additional strength.
Installed the Currie 3.25:1 differential, torque arm, and side subframe braces.
Richard
67 Super Snake
TKO600 Trans
Eleanor Registry
Old 05-20-2007, 01:02 PM
Got the chance to install the X Brace, Rear Shelby 12" brakes and lines, UP front coilover suspension and Shelby 13" front brakes. Wow, a lot more work behind the scenes that is not mentioned.
Richard
67 Super Snake
TKO600 Trans
Eleanor Registry
