Old 03-07-2020, 12:28 PM
Stielow's Avatar
Stielow Stielow is offline
To get at the dry sump tank when the car is assembled we made this accesses panel. The rear part of the passenger inner fender well is removable.
Stielow Engineering
The Following 3 Users Say Thank You to Stielow For This Useful Post:
dhutton (03-07-2020), fleetus macmullitz (03-07-2020), WILWAXU (03-08-2020)
  #212
Old 03-07-2020, 12:29 PM
Stielow's Avatar
Holley’s transmission crossmember.
Stielow Engineering
Old 03-07-2020, 12:32 PM
Stielow's Avatar
Random photos
Stielow Engineering
The Following 2 Users Say Thank You to Stielow For This Useful Post:
fleetus macmullitz (03-07-2020), Roscoe03 (03-08-2020)
  #214
Old 03-07-2020, 07:46 PM
kwhizz's Avatar
kwhizz kwhizz is offline
A work of ART !!!!!!!!!
Old 03-07-2020, 10:07 PM
64G-lark's Avatar
64G-lark 64G-lark is offline
Mark can you tell us where you source the radiator mounts? Looking for ones like that. Thanks.
Old 03-08-2020, 07:50 AM
Stielow's Avatar
The lower mounts are C6 Corvette on stock style pins. The weight of the cooling stack sits on mounts that bolts to the frame. The radiator, intercooler, ac condenser and fan as an assembly. It has some weight.
The side mount is a fabricated mount using a grommet. The radiator side has a turned pin. The other brakes is a fabricated mount. This constrains the rad for after but allows for expansion.
The system allows the radiator to float. I have failed a number of radiators do to ridged mounts. We want to it to have room to expand as it heats up.
Again look at a way a stock (New Car) radiator is mounted. Copy that.
Mark
Stielow Engineering
cpd004 (09-11-2020), ProTouring442 (10-12-2022)
  #217
Old 03-08-2020, 07:53 AM
Stielow's Avatar
Thanks Ken! This is the last set of Alex ends you made for me.
DSE makes a system now, but I like my set up a little better.
Thanks!
Stielow Engineering
Old 03-08-2020, 08:40 AM
Stielow's Avatar
Originally Posted by jmac View Post
Wow! You've been busy! Those brake lines look great, I can't believe how close the balancer is to the cross member.
What's going on in the rear? I see two catch cans/vents, one for the gas tank and one for the rear? What's that next to the Vaporworx controller?
Thanks for sharing!
John
The balancer has clearance. We jogged the brake lines to allow a bigger lower pulley. We are going to notch the frame for more clearance.
Stielow Engineering
Old 03-08-2020, 09:30 AM
RdHuggr68 RdHuggr68 is offline
Mark
Mark, I always enjoy keeping up with your builds, very informative. The grommets for your radiator are they from McMaster-Carr? Thanks again
Old 03-08-2020, 09:54 AM
Stielow's Avatar
Sorry yes McMaster Carr.
Stielow Engineering
The Following User Says Thank You to Stielow For This Useful Post:
RdHuggr68 (03-08-2020)
