Old 11-14-2006, 07:50 PM
bulldogchevy bulldogchevy is offline
Default 427 Twin Turbo Small Block
HATE TO DO IT--BUT NEED TO SELL MY NELSON BUILT ALL ALUMINUM 427 TWIN TURBO.
TO VIEW THE DYNO CLICK ON THE LINK BELOW (WHICH WILL BRING YOU TO THE NELSON RACING WEB SITE) AND CLICK ON THE 13TH ENGINE DYNO DOWN "DYNO PULL TWIN TURBO 427"[list]
http://www.nelsonracingengines.com/videos-tt.html
BELOW IS A LIST OF ALL THE COMPONENTS ON THE NELSON ENGINE
-ALUMINUM DART BLOCK
-55MM CAM RAISED CAM SHAFT .391
-HOWARDS/CALLIES 4340 CRANKSHAFT 4.0 STROKE
-4340 FORGED H BEAM RODS
-JE PISTONS
-HELL FIRE RINGS
-CUSTOM NRE ROLLER CAMSHAFT 55MM
-TALL ROLLER LIFTERS
-DOUBLE ROLLER TIMING SPECIAL FOR .391
-PRO ACTION ALUMINUM CYLINDER HEADS , 235 CC INTAKE RUNNER INCONEL EX VALVES
-.080 WALL PUSHRODS
-ROLLER ROCKERS
-ARP HARDWARE
-SFI HARMONIC DAMPER
-HOGAN SHEET METAL INTAKE MANIFOLD
-TWIN 62 MM THROTTLE BODY
-SHEET METAL VALVE COVERS
-ALUMINUM CHECK BALL BAFFLED HI QUART OIL PAN WITH -12 DRAIN BACKS
-STAINLESS STEEL EX HEADERS
-2 72MMITS TURBO CHARGERS
-2 PRO WASTE GATES
-ELECTROMOTIVE TEC 3 ENGINE MANAGEMENT SYSTEM
-ELECTROMOTIVE CRANK TRIGGER IGNITION
-MSD BILLET OIL PUMP DRIVE
HUDSON MA $28,500
