Old 03-16-2022, 10:50 PM
SuperBuickGuy SuperBuickGuy is offline
Originally Posted by Panteracer View Post
I like the struts layed back a little so matching the
back of the car. I have changed the ends on mine
multiple times... Starting to rework the ones on my
Gt-1 race car plus raising the wing some
Bob
Love your car.
I need to do some rule diving again... moving the wing back might help, but C3 Corvettes get nose light - so moving the point where it's pushing down further back might not be a good idea on the track.... wonder if they'd notice if I swapped struts between the track session and the autox....
Old 03-18-2022, 04:59 PM
well, look what's back?
dark bronze
fuel cap too
I like. a lot
truly better then I expected.... I thought I went too dark
with the wing in place
Old 03-19-2022, 09:46 PM
a bit done tonight
more fittings - most important is that stainless one
the problem is I welded a pipe fitting for the return when I needed an AN one... oops... will use it as a vent
and welded
in other news, I'm a really bad influence.... the red Corvette owner has bbc plans
Old 03-20-2022, 07:45 AM
I think you picked a good color with the rims
SuperBuickGuy (03-20-2022)
  #85
Old 03-20-2022, 08:49 AM
Ricochet's Avatar
Ricochet Ricochet is offline
Looks great!!!
What color exactly are the wheels? I'm looking for a titanium/bronze color for my centers. Assuming they are satin cleared as well?
Brent
Old 03-20-2022, 10:09 PM
Originally Posted by Ricochet View Post
Looks great!!!
I'll have to call the powder coater... it was a special order dark bronze.
Old 03-20-2022, 10:10 PM
Spoiler is supported by the frame... I also put window glue in place to keep the warp and vibration transmission to a minimum
measuring done, time to make the tank support
keep in mind I was about 150 lbs light for where I'm racing.... I'll probably gain 30 or 40 lbs in this... all on the correct end
framework installed
not in love with the straps, however, I plan on supporting the defuser off them - so function trumps form
up the tank goes - the metal duct tape was put in place to keep the fiberglass from sagging when I filled the holes for the luggage rack
very close - I wanted to make it solid but I wouldn't be able to get the fuel pump out if I did
last test fit, next up with the fill neck, lines attached, electrical attached and rubber protection on the metal bands
Old 03-21-2022, 09:00 AM
Splitter material... best source?
Old 03-21-2022, 09:01 PM
a little further
wheels with tires on them
cut down the fill neck so I can use a flexible rubber hose for the offset
padding/rubber top and bottom
getting close... waiting on a fitting and the fill hose
The Following User Says Thank You to SuperBuickGuy For This Useful Post:
camcojb (03-22-2022)
  #90
Old 03-22-2022, 10:04 PM
it runs again...
interior is back in it
next up? front stuff
looks all buff in the back.... but more to do...thankfully, this isn't a take the car mostly apart deal
also need to program and do weighing
