Old 10-24-2007, 10:05 PM
ohcbird's Avatar
ohcbird ohcbird is offline
Lightbulb HID kit
Try Nathan Shue @ www.HID-source.com he has retro kits for most everything, and has been on LSITECH.com for quite some time. I've installed 3 of his kits (my 06 Solstice, 93 4 runner and my 68 Firebird).
Old 10-25-2007, 11:53 AM
QSPres QSPres is offline
Banned
Well, HID-source is out for me. $375 for the low beams, $375 for the highs....
Must be gold in there...
Old 10-25-2007, 02:44 PM
ZZ3ElCamino's Avatar
ZZ3ElCamino ZZ3ElCamino is offline
Originally Posted by Musclerodz
Kit will be $249. Trying to get custom boxing made so I can ship nicely as a kit.
Mike, is there really no modification required for on the core support to make these work? Just wiring in the relays?
Jason
www.fquick.com/ZZ3ElCamino
Old 10-26-2007, 12:36 PM
Musclerodz's Avatar
No mods required on a 65 Lemans and no mods on V8TV's '69 Chevelle to the core support or headlight buckets.
Mike
Mike Redpath
Musclerodz & Customz
facebook page
Old 11-05-2007, 12:03 PM
Banned
Got one side completely stripped, painted, and assembled today. They look great! I have the other side stripped, painted and 99% assembled, but the guy I ordered the headlight adjusters from only sent 4, I needed 8.
Big ups to 69Bird for recommending the e-bay kit. Even with my time, POR 15, new headlight adjusters ($14.50), springs ($7.00), the headlights ($70.00)and the headlight door mounting kit (18.00) I wasn't anywhere near $240 and everything from the headlight base plate to the lights themselves are brand new!
There were three modifications that I had to make to get them to work:
I had to modify the trim rings by laying them on a flat surface and rolling in the lips to go over the headlight glass.
I also had to trim the bottoms of the headlight mounting cups because the new headlight bodies are much longer than the factory bodies. They actually stick out through the bottoms of the mounting cups. By a good 2"!
I also had to enlarge a couple of the slots that are in the mounting cups for the base of the headlight lens to fit in. The lugs in the headlights do not match up with the slots in the cups. A dremel tool with a small cutting wheel and a small grinding stone made quick work of that.
But it was still worth it in my opinion as the price was nice and none of what I had to do took longer than 30 minutes. Everything that I used other than the POR 15 was purchased on E-bay, with a fairly significant savings over "retail"....
Old 10-24-2007, 04:05 AM
Banned
Only thing I found on e-bay is a set of 7" 71+ Chevelle headlight housings and bulbs. No wiring or relays. The $25 price tells me its not great quality, even though the housings are supposedly glass.....
If the quality and price is reasonable, I'd rather get everything at once.
Old 10-24-2007, 05:41 AM
COYBILT's Avatar
COYBILT COYBILT is offline
when you get these in let us all know
I need a setup for my 65 gto
1965 GTO convertible
2009 GM Design Award winner
Triple black with Subtle yet massive Modifications.
