Old 08-30-2018, 09:19 AM
syborg tt's Avatar
Moving on to the header removal. Okay let’s just say this design worked perfectly as it was a 20 minute job to remove them.
When they go back in there will be ARP Header Studs going back in.
Just a quick shot of the Powder Coated rear end. Need to take inventory of all the hardware and order the new ARP 6 point stainless bolts and new EBC rotors in black.
marty-mj
Old 08-30-2018, 09:20 AM
syborg tt's Avatar
Almost forgot that I worked on three fat bikes and did a carbon bar swap on Mikes 27.5 mid-fat bike.
These three posts where from July 15th
marty-mj
fleet (09-04-2018)
Old 09-07-2018, 07:25 PM
syborg tt's Avatar
So the header are back from getting coated and the down tubes are wrapped in DEI Ti Thermal wrap. I also added studs to make it even easier to install the headers which takes all of 10 minutes for both sides.
marty-mj
Old 12-09-2018, 06:28 PM
syborg tt's Avatar
Need to shorten the exhaust by 1/4'' and also plan to to wrap the mufflers with the DEI Muffler Shield.
Mike's pretty darn good making a straight cut with a Sawzall
small learning curve here for both of us.
marty-mj
Old 12-09-2018, 06:51 PM
syborg tt's Avatar
Next Up put some DEI wrap on the tailpipes
This bike stand is really getting a workout.
marty-mj
Old 12-09-2018, 07:16 PM
syborg tt's Avatar
New Totally Stainless Sway Bar Links
The original set was a little short so we had to send them back.
Before
After
marty-mj
Old 12-09-2018, 07:37 PM
syborg tt's Avatar
Still updating the factory hardware to ARP or hardware from the guys at Totally Stainless.
Of course the inner fender is in the way. However since they are fiberglass/Carbon that is easily solved.
marty-mj
Old 12-09-2018, 08:09 PM
fleet's Avatar
fleet fleet is offline
Enjoying seeing this one fleshed out MJ.
The Following User Says Thank You to fleet For This Useful Post:
syborg tt (01-23-2024)
Old 09-07-2018, 07:28 PM
syborg tt's Avatar
While I was working on the car I decided I needed to make a down and dirty hood prop as my hood kept falling on me.
Thank goodness for PVC pipe and a dremel.
I wrapped it in red electrical tape so I would remember to remove it. Plus it adds a little friction as it snaps over the shock rod nicely now.
marty-mj
Old 09-07-2018, 07:50 PM
Are the hood struts worn out or did they never work great to begin with?
