Old 10-11-2011, 01:23 AM
tyoneal's Avatar
tyoneal tyoneal is offline
Default Request help locating the right Radiator
Hello:
I would like some advice regarding a couple of questions.
I currently have a sbc with a 400 cid (Bowtie Block) in my car. It is very healthy, estimated at 525-550 hp. It was an original San Diego car and had no issues with over heating. Being in Texas, and with the installation of Vintage Air, the car wants and does over heat unless moving at quite a good clip.
My ideas to rectify this issue are:
a) It has electric fans on it now with a built in cowl system to promote the air to being pulled through the radiator. My thoughts are to look and see if I can close off any additional passages in front of the radiator that would not allow incoming air to bypass the radiator from underneath or otherwise.
b) Get a larger Radiator that is made to be used with the amount of power that the engine is putting out. Seems like many of the Radiator manufacturers seem to cut off the small and the larger radiators based on the engine power output, and the separation point is in between 500-600 Horse Power.
c) I would like some radiator advice from some of you who have had to move up to a crossflow, big radiator from a quality company, and use a Mark VII Fan to go with it. I have read on numerous occasions that by using that fan along with a larger more efficient radiator, that most if not all of someone's overheating issues can be handled using these two parts together. (Given there is not a Major Engine problem preexisting already)
Any and all feedback would be greatly appreciated regarding this. I am tired of dealing with this issue and want to get the car out a lot more without having to worry about it getting to hot.
Thanks in advance.
Regards,
Ty O'Neal
BTW: I have a Mark VII or VIII fan already set up for a 69 Camaro, and I really just need to acquire a terrific radiator to get back out on the road.
Project, "EnGULFed"
Ty O'Neal
"She Devil" aka. Betty
1969/70 Camaro SS
427 LS3, 600
Keisler Road and Track T-56
"Chester's '65"
1965 Buick Riviera
Old 10-11-2011, 10:46 AM
Real simple --- AUTORAD radiator and core support..... big crossflow with dual fans.... and put on a SPAL PWM fan controller. Wired properly it will bang both fans at high speed when the A/C calls for it -- and runs them AFTER the A/C is off for a cool-down period. It also just runs fan #1 at half speed and then ramps it up until you need fan #2.
Now -- You said you have a SBC 400..... and they were notorious (wrongly so) for overheating. The reason that block had overheat issues was that people stuck SBC heads on 'em without drilling the steam hole in the head AND the gasket....
Old 10-11-2011, 11:13 AM
wellis77's Avatar
wellis77 wellis77 is offline
Another option is to talk with the guys at Ron Davis. I need a custom radiator for my application and they were great talking through what I need, don't need, and how I should go about sizing up my project.
Will Ellis
Project SCUD, 1969 Dodge Dart Swinger, 1/2 Dart / 1/2 Viper
Old 10-11-2011, 11:46 AM
My BeCool rad with dual Spal fans cool my 400 block just fine in my 68.
Old 10-11-2011, 11:57 AM
HRBS's Avatar
HRBS HRBS is offline
Default Prc
Try the guys at PRC (Performance Rod & Custom).
They can custom build to order. Tell them exactly what you have written here and provide them some dimensions and in a few weeks you will have your problems solved. I used to be a BeCool guy untill I got a PRC system in our Shop Bitch Nova. Needless to say, every car leaving here from now on will run a PRC.
HRBS on Facebook
Old 02-09-2012, 01:39 AM
tyoneal's Avatar
Is your 400 putting out 550hp?
I think this is part of the cause for the overheating, + the A/C.
Ty
Project, "EnGULFed"
Ty O'Neal
1969/70 Camaro SS
427 LS3, 600
"Chester's '65"
1965 Buick Riviera
Old 02-09-2012, 02:33 AM
tyoneal's Avatar
Can you elaborate on this for me? I believe the engine was assembled by a pretty competent engine builder.
This IS the Engine that Mark Magers used in his car. Here is some of the information about the car a number of years ago, I will see what else I have so I can give you more information.
https://lateral-g.net/members/magers/
Hope this helps.
Ty
Project, "EnGULFed"
Ty O'Neal
1969/70 Camaro SS
427 LS3, 600
"Chester's '65"
1965 Buick Riviera
Old 02-09-2012, 06:54 AM
Many people don't realize that the 400 block used a couple "steam holes" to cool their Siamese cylinders... and if the gaskets don't have the right holes they block the passages -- or if the heads aren't drilled for the 400 block then they're blocked... so you have to have the right gaskets AND the right heads or a 400 block will overheat.
Old 02-09-2012, 09:34 AM
intocarss's Avatar
Convert SBC 350 Head for use on a 400
http://www.gregsengine.com/convertin...ds-to-400.html
Old 02-09-2012, 09:46 AM
Ty
Yes, around 550-570 hp I estimate.
FYI, I am only endorsing the BeCool because (1) it works well for me, and (2) I got my setup for $520 off craigslist ($1100 new for my setup). I don't think I'd pay $1100 for it though.
