Old 02-20-2013, 11:08 PM
That's what I assumed, but I'm iffy on the idea of a sensor hanging out the bottom of the housing. I might have to reconsider one of my gauge choices though if I'm going to do enough road course events.
Thanx!
I hear ya Bryan. This could be an option?
https://www.pegasusautoracing.com/pr...p?Product=1227
Old 02-20-2013, 11:17 PM
Ok more parts coming in as I wait for the big pallet gets here.
Did lots of research on E85 and came with this guy as my carb builder. Braswell and Hendrick Motorsports have had him do work for them.
http://marksullense85carburetors.com/
It's a Holley 950HP main body with numerous modifications for E85. Due to E85 requiring approx 30% more volume than gas, it has #97 jets in it. The relatively small 1.375" venturi size is intentional for excellent throttle response and mid range torque, and it will be a sacrifice of hp on the top end. I figure I got Rob beat on hp by a mile, so I am going after the torque to make it a sweep.
And of course an update here would be incomplete without some Nascar reference of some kind. Got some carbon fiber brake cooling ducts that fit over the lower valance openings almost perfectly. $35 on ebay. And yeah it's Toyota stuff, what can ya do.
The engine is ALMOST ready to the front of the line. All the engines that have race deadlines move up to the front at the shop Mike said. I told him I have a really important dyno contest on the internet I am late for -- does that count?
Oh BTW, that little 781 cube motor ONLY made 1540 hp and 1200 ft lbs. They were pretty disappointed actually.
Old 02-21-2013, 07:51 AM
carbuff's Avatar
carbuff carbuff is offline
Well, I won't have a cooler at this point, so I can't really use it. Perhaps you can?
I think I'm going to have Eric weld in a temp sensor probe on the housing, maybe on the lower front area so that the probe would come out facing forward. The sensor itself is pretty small, so it should fit ok. The housing is out right now for some underbody paint and cleanup before final install, so now's the time.
