Old 08-29-2013, 04:15 PM
8hg383 8hg383 is offline
Default Warning do not buy Stainless Works big block headers
Been a member of this site for while now but have just been happy looking at the great cars and ideas people have.
Unfortunitly my first post is to let people no of the poor product and customer service i have received from Paul at Stainless Works.
I am building a 1969 Camaro here in Australia and ordered a set of big block headers to suit my car.
They will not fit as they are hard against the steering box and idler arm.
Paul has said send them back but i will have to pay for shipping $400.
Unfortuitly i dented a couple of pipes to try and get them to fit as i didnt want the hassle in sending them back but its to the point now that they will not fit no matter how much i dent them so now Paul want take them back.
I now have to get them cut up and pipes moved the LH header has to be made again which here in Australia is going to cost at least $1000. I have asked Paul if we can come to some sort of compromise but he is not interested saying that they should fit they dont not even close to fitting.
So to cut a long story short think again before buying SW headers i am sure there is better headers out there and diffintley better service the headers will now i owe me at least $3000 thanks Stainless Works.
Old 08-29-2013, 04:23 PM
Sounds like you have the wrong frame mounts. Pretty common issue. The correct big block frame pads move the engine over 1/2"+ to the passenger side, and the frame pad is taller on the drivers side; this gains the clearance needed to clear the steering box with the wider big block. Many people do not have the correct frame pads and since most headers were made off a real big block car with the correct big block frame mounts they don't fit with the engine centered in the chassis like a small block.
This happens with most headers, other than the few like Lemons who actually make headers specifically for a big block in the small block location. Here's a pic and some more info:
http://www.camaros.org/engine.shtml#EngineMounting
Old 08-29-2013, 04:48 PM
clill's Avatar
clill clill is offline
I'm with Jody on this. It sounds like you have smallblock frame mounts. That is where forums like these come in very handy. If you had asked here we probably could have helped you before the headers got messed up. I have had no problems with their headers. Can you post pics ? Even the trans crossmember is different on a big block car.
Old 08-29-2013, 05:02 PM
coolwelder62's Avatar
If you find out that you have the wrong frame stand's,the ding's can be fixed.Build some flange & collector block off plate's,then put a valve stem in the collector.Heat the dinged area to a light dall red,then fill the capped header tube with no more than about 60PSI of air pressure at first.The dent should slowly push it's way out.After it's cooled start using scotch brite to work out the discrolored area.I've fixed many car and motorcycle header's this way.Just take your time and work slowly.
Old 08-29-2013, 05:12 PM
Ron in SoCal's Avatar
I have a couple of brand new BB frame stands you can have if you determine you have the wrong ones.
You pay shipping, haha...
Ron in SoCal
69 Camaro in progress
Old 08-29-2013, 05:13 PM
chr2002ca's Avatar
chr2002ca chr2002ca is offline
Not necessarily true. I have NOS big block frame stands for my 69 that shift the engine to the passenger side properly and I still had to dimple my Hedmans and would've had to dimple a set of Hookers to fit near the steering box. If the #5 header tube does not loop over the #7 tube, then the #5 tube and possibly #7 tube are probably going to hit a power steering gear box no matter how correct the frame stands are. I've seen people place shims under the drivers side frame stands to create extra clearance. Some power steering boxes stick out more than others also. I had to rework my #7 tube when I changed to a different ps box.
Additionally, he said the headers are hitting his idler arm also, so shifting the engine more to the passenger side would make this worse. I saw a thread where a guy had the same problem with his Lemons and had to send that side back to get reworked slightly.
It's a difficult fit for any header manufacturer and it's a crappy situation for the original poster because of how pricey the stainless headers are and how pricey it is to return them to have them corrected.
Chris Robinson
1969 Camaro SS/RS, 489 ZL-1 MPFI, T-56 Mag
Old 08-29-2013, 05:19 PM
Sieg's Avatar
Sieg Sieg is offline
Originally Posted by coolwelder62 View Post
If you find out that you have the wrong frame stand's, the ding's can be fixed. Build some flange & collector block off plates, then put a valve stem in the collector. Heat the dinged area to a light dull red, then fill the capped header tube with no more than about 60PSI of air pressure at first. The dent should slowly push it's way out. After it's cooled start using scotch brite to work out the discolored area. I've fixed many car and motorcycle header's this way. Just take your time and work slowly.
This is Bomb Making 101, but it is effective, just be careful. The heat causes an increase in psi..........so baby steps.
I know more than one motorcycle friend thats launched a plug and put a hole in a garage wall and one window.......and a couple pairs of knickers.
It's a difficult fit for any header manufacture. It's a crappy situation for the original poster because of how pricey the stainless headers are and how pricey it is to return them to have them corrected.
I understand that not all headers fit correctly, but if he has different frame pads than what the manufacturer used in their header design he has little chance of them fitting without modding them. My Hookers fit perfectly (although tight) on my 69 Camaro with the correct GM big block frame pads.
Old 08-29-2013, 05:30 PM
chr2002ca's Avatar
Congratulations. You're one of the few! I'm jealous. Hooker makes 3 or 4 different models(design, primary tube sizes) each with completely different fitments and issues. I tried Hooker 2205's earlier this year and they fit very poorly and the craftsmanship was just horrible and I sent them back to Summit and decided to just re-work my Hedmans. I read from others that other models of Hookers(that have the #5 tube loop over the #7 tube) had no issues with fitment at the steering box, but had severe issues with it hitting their road racing oil pan or that they hung too low or hit somewhere else, so I didn't even want to try those. I've also heard that ordering the same model of headers twice from Hooker could get you 2 different fitments depending on how the guy building them was feeling that day.
It's simply a role of the dice. Even the priciest headers sometimes don't fit. I went to a physically smaller power steering box and it actually fit worse due to how certain areas stick out more than others. It's difficult/impossible for header manufacturers to account for something like that.
If I was to recommend any header, I'd have to go with Lemons also. They seem to have the least amount of fitment issues and most of time fit perfectly out of the box.
Chris Robinson
Old 08-29-2013, 05:32 PM
I have got the big block mounts on they are Chris Alston big block engine and frame mounts i have measured them and comparied them with standard big block mounts and there are the same height.
I checked all that before even contacting SW as i wanted to be 100% sure i was doing the right thing befor blamming someone else.
I think they are to suit steering rack vehicle not box as there are that far away from getting them to fit.
The thing is they are hard against the box and idler arm so moving the motor left or right will not work nor will moving the motor up as the number one pipe is hard against the steering box body from the top of the box to the bottom.
All advice is appreciated.
