Old 10-26-2013, 12:33 PM
groovyjay's Avatar
groovyjay groovyjay is offline
The original Grand Sports had a trunk with no floor, but a spare tire carrier for the endurance races, which required a spare tire.
I'm not planning on using a spare, but I was planning on using all the spare room to make a usable trunk for this car. I think I managed to get pretty decent size space for some traveling essentials i.e. tooth brush and wallet.
The body kit came with some sort of pieces for this, but I only ended up using the bit which directs the air out from the rear air holes (that didn't sound right... )
The whole transmission tunnel was raised and widened for a T56 first and then I made this slot for the handbrake handle to live in.
Old 11-03-2013, 11:18 AM
groovyjay's Avatar
Finally after all the dusty fiberglass work was done it was time to finally start the assembly. I blasted the frame again and had it powdercoated along with all the suspension stuff. I've done always black frames in my builds, but this time I wanted to do something different.
This is always the fun part, when you have a nice clean frame and tons of new parts that need to go on it. These cars are so simple to put together that you can get a lot done in a day.
Front end stuff going in. JMRP tubular A-arms, Home made rack n pinion, custom ordered sway bars and QA1 coil overs, I ended up using only the bare shells of the shock as everything inside was custom made to work better in this car. The guy who does all my shocks is responsible for a lot WRC cars shocks, so if they can jump 100ft in those cars and come down and keep pounding on through the stages, the shocks really need to work well. I plan to keep this car on the ground but still it has made a huge difference in my previous builds, just to tune the shocks.
T56 required the cross member to be modified.
Custom made gas tank, it was also relocated from the rear of the car to the center to get even better balance. Capacity is also almost doubled compared to stock tank.
More about the assembly later...
Old 11-04-2013, 07:24 AM
Payton King's Avatar
Default Looking good
Can't wait to see this one come together
Old 11-04-2013, 09:33 AM
aggie91's Avatar
aggie91 aggie91 is offline
Wow, that's dedication to that car. I like the couch too!
Karl
1965 Chevrolet C10
1982 Chevrolet C10 - My son's Truck - Sunburn
Old 11-04-2013, 09:56 AM
fleetus macmullitz's Avatar
X2...you might be more fanatical than some of those F-body owners that start with those roach coaches we see on here.
With this mid '60 Vette Jay...no problem bein' Groovy.
