Old 05-01-2020, 09:47 PM
Grnova's Avatar
Grnova Grnova is offline
Just got my RB spoiler today curious to see what you do. I was looking at it a different way hmm...
Tim
Old 05-04-2020, 05:50 AM
bkswede bkswede is offline
I’m planning on positioning mine similar to the way Ring Brothers mounted it on their Mustang, not as it was sitting on the deck lid of my car in the pictures (i.e., so it looks more like a duck bill spoiler than a blade and the hinges will be visible). How are you thinking about positioning yours?
63 Chevy II - Build in Progress
2017 Camaro ZL1
2010 Mercedes C63 AMG
Old 05-04-2020, 07:59 AM
Grnova's Avatar
Here is what I was doing a little different and lower down on trunk.
Tim
The Following 2 Users Say Thank You to Grnova For This Useful Post:
Goosesdad (05-04-2020), syborg tt (12-14-2020)
Old 05-04-2020, 05:39 PM
Default ‘63 Chevy II Pro-Touring Build
Thanks for sharing - that actually looks really good in that position. The Ring Brothers Mustang has it mounted lower on the deck lid as well, I just wasn’t sure how it would look on the Nova. Yours is flipped 180 degrees from the way Ring Brothers mounted theirs - allows the blade of the spoiler to be higher and more prominent. I could see mounting it as you have shown, or, potentially, higher on the deck lid (before it starts sloping down) and flipped 180 degrees from yours... wish I could actually experiment with it. Due to COVID restrictions, I haven’t been able to see my car for weeks, let alone the new spoiler!
2017 Camaro ZL1
Old 05-14-2020, 08:26 PM
Finally was able to make a trip to WI today to see, first hand, progress on the Nova... been a long time - almost six weeks!
Last week, Kurt sent me some pictures of the Nova... he was able to get the interior primed and painted (just floors and other areas of the interior that won’t be visible when the car is finished).
He also was able to get the underside of the car finished in Upol...
Drove over to WI today and was surprised to see that he had the car painted and was well into wet sanding... looked great! Color is stealthy for sure... as always with paint, pics don’t really do it justice. Appears a little darker in pictures than it actually is. Hope to be done with wet sanding and buffing early next week, then can start assembly... been a long time coming
After wet sanding and buffing, inner fenders, firewall, core support, etc will be sprayed a satin black. Then exterior trim, bumpers, etc all painted carbon black metallic. Interior will be sprayed later, likely a darker charcoal gray metallic. I’m really excited to see the progress and can’t wait for the final assembly to start!
2017 Camaro ZL1
The Following 3 Users Say Thank You to bkswede For This Useful Post:
camcojb (05-14-2020), Roscoe03 (05-14-2020), syborg tt (08-03-2020)
Old 05-14-2020, 11:09 PM
camcojb camcojb is online now
Old 05-16-2020, 12:21 PM
Goosesdad's Avatar
Looks fantastic!!
Have a great day!
John
My Build Thread:
Old 06-18-2020, 06:43 PM
Quick update on progress made on the Nova over the last few weeks. Kurt was able to finish wet sanding the exterior and has buffed the body. Doors, front fenders, hood and trunk are wet sanded, but still finishing the buffing process. Due to scheduling issues in the shop, Kurt wanted to focus on getting the interior painted, sound deadener sprayed, and firewall painted before finishing the final buffing on other panels. Attached are some pictures of the body that I took when I visited last week. He does three levels of buffing/polishing (each with a successively finer polishing compound and pad). These pictures were taken after the first level of polishing.
After completing the polishing on the shell, Kurt masked the body off to paint the interior. We ended up using Nightfall Gray Metallic, a color that’s a middle ground between the Shark Gray Metallic body color and the Carbon Black Metallc that the trim, bumpers, etc will be painted in. I’m a big fan of the Nightfall Gray Metallc... almost ordered my 2017 ZL-1 in that color. We wanted a little contrast to the body color and the darker color goes better with the color of the leather for my seats. Kurt also painted the steering wheel column, steering wheel, steering column mount, glove box, etc. Some photos below.
As a reminder, here are my Recaros I had custom done...
After we got the interior painted, Kurt masked off the freshly painted interior areas and we sprayed sound deadener on the floors, roof, inside the doors, inside firewall, inside rear quarters, trunk, etc. We used a product from Second Skin audio called Spectrum. Really helps to eliminate resonance and noise from vibrations inside the car. Sprays on a bit like a bed liner. Kurt has never used it before, but was excited to try it and thought it went on really well. We did three coats, approximately 1 mil thickness each.
Finally, after finishing the interior, he was able to get the shell off the rotisserie and on a cart where he was able to spray the firewall in a satin black. Inner fender panels, underside of the hood, core support, etc. will be painted in the same color.
Next week, the guys will be installing suspension back under the car, as well as the engine. It’s really exciting to see the progress and can’t wait for assembly to start! Hope all is well,
Brian
2017 Camaro ZL1
The Following 2 Users Say Thank You to bkswede For This Useful Post:
Goosesdad (06-19-2020), syborg tt (08-03-2020)
Old 06-19-2020, 11:14 AM
The paint looks great, and that sound insulation help a lot.
Old 06-25-2020, 07:34 PM
Stopped by AutoKraft today to take a quick look at the Nova... Kurt’s team was able to get all of the tape and paper off the car, get it off the cart, get front subframe mounted as well as rear Quadra link and 9 inch... I have to say, it’s a great feeling to see the car painted, with suspension back under it and the Forgelines on! Starting to look like a car again... been a long time during paint and body phase. I think the plan for next week is to finish buffing hood, doors, trunk and front fenders, get engine and transmission back in it, and then hang doors and front fenders. Exciting to see the progress!
Sent from my iPad using Tapatalk
2017 Camaro ZL1
camcojb (07-09-2020), streetbird (06-27-2020), syborg tt (08-03-2020)
