Old 07-31-2020, 08:23 PM
bkswede bkswede is offline
Default ‘63 Chevy II Pro-Touring Build
Made a quick run to Eau Claire today to check in on the Nova. Engine and transmission should go in on Monday. Kurt ordered a clutch bleeder from Tick Performance and the fitting was for the wrong slave cylinder, so he had to reorder. New one came in today, so driveline should go in Monday.
They’re also deep into wiring, which is going to be a big job. I’ve got a new American Autowire wiring harness that they’re installing, but they’re adding to that the Holley Dominator ECU harness, the Holley drive by wire harness, the Holley digital dash harness, various input/outputs for the ECU and dash (oil temperature, left/right turn signals, high beam, fuel level sensor, second wideband oxygen sensor, pulse width modulation fan control, etc), Vaporworx PWM fuel module control, Digital Guard Dawg keyless entry, PWM control for the dual Spal fans, etc. It’s a maze of wires - glad that Kurt and his team are as conscientious as they are!
They’ve got the rear windows in, too. Side windows and vent windows will go in next week - just waiting for some vertical rigid channel for the front windows, which should be in sometime next week. Door handles were painted black, as was trim around the windows. Windows have a smoked gray tint - pretty subtle, but, man, does it look great in person with the gray body color and the black trim.
Hope to have some pictures of the motor and transmission in early next week, along with front fenders, core support and grill!
63 Chevy II - Build in Progress
2017 Camaro ZL1
2010 Mercedes C63 AMG
The Following 4 Users Say Thank You to bkswede For This Useful Post:
Chevelle (08-04-2020), EVIL SS (08-04-2020), syborg tt (08-03-2020), WILWAXU (08-04-2020)
Old 08-03-2020, 06:16 PM
syborg tt's Avatar
Holy **** !!
I just found this thread and all I can say is I’m blown away. Looking forward to more progress pictures and can’t wait to see this one finished.
marty-mj
Old 08-04-2020, 08:36 PM
Holy **** !!
Thanks for the kind words! Will try to keep the updates coming, and I, too, can’t wait until it is finished!!
2017 Camaro ZL1
The Following User Says Thank You to bkswede For This Useful Post:
syborg tt (09-05-2020)
Old 08-05-2020, 08:58 PM
Minor setback... as we attempted to get the driveline in, we had some issues with the Katech LS9X clutch I had planned to use. The LS9X clutch is a package developed by Katech combining the dual disc clutch that was used in the C6 ZR1 Corvette with a flywheel adapted for the 6 bolt crankshaft of most LS engines. As it turns out, the LS9 clutch is a meaningfully “thicker” clutch and won’t fit within a standard LS bellhousing. I’m using a standard Quick Time LS bellhousing.
In order to use the LS9X clutch within the Quick Time bell housing, you need a spacer between the transmission and the bellhousing that is approximately .85”, which moves the transmission back in the chassis .85”. D&D used to sell an aluminum spacer that they CNC machined to provide the appropriate clearance (Stielow used one of the D&D spacers when he put a LS9X clutch in his Mayhem build). I’ve already positioned the transmission cross member, transmission tunnel, as well as a custom QA1 carbon fiber driveshaft assuming no spacer. So the D&D spacer was not an option for me.
Based on some quick research and through discussions with the folks at Tick Performance, I ended up purchasing a Monster LT1-S clutch, and will need to sell the Katech LS9-X clutch package. The Monster clutch is similar in concept to the Katech LS9X clutch, but a newer variation. While the Katech LS9X clutch uses the C6 ZR1 factory dual disc clutch with a modified flywheel for 6 bolt crankshafts, the Monster LT1-S clutch uses the GM OEM dual disc set up from the C7 Corvette, again with a flywheel modified to work with LS engines. Importantly, the Monster clutch is physically smaller than the Katech clutch and fits within the standard QuickTime bell housing.
I’ve read a lot of great reviews about the Monster clutch; hopefully it works well in my application. Like the Katech LS9X clutch, the Monster clutch is supposed to have a factory feel, with absolutely no rattling or chatter that is common with dual disc clutches.
Back moving in the right direction, but the whole thing has pushed us back a bit. We won’t get the clutch until Friday so motor and transmission won’t go in until early next week. A little frustrating, but not unusual to have a few bumps in the road along the way...
2017 Camaro ZL1
The Following 3 Users Say Thank You to bkswede For This Useful Post:
EVIL SS (08-06-2020), Goosesdad (08-06-2020), syborg tt (12-14-2020)
Old 08-06-2020, 07:00 AM
EVIL SS EVIL SS is offline
As you said, while frustrating at least you found a solution and it wasn't too hard like, more fab work or rework. Looking forward to seeing the final results. It's coming out awesome!
Dave
Old 08-07-2020, 08:20 PM
Dave
Thanks Dave... definitely lucky that we don’t have to do any more fab work! New clutch arrived today, so hopefully we can get engine and trans in next week without further issues...
Sent from my iPad using Tapatalk
2017 Camaro ZL1
EVIL SS (08-08-2020)
Old 08-07-2020, 08:42 PM
Have been looking all over for the “right” steering wheel for the Nova. I was looking for something with a flat bottom (but not too crazy) that fit the look of the interior. Looked at a bunch of Momo wheels, Sparco wheels, and NRG wheels. The wheel I like best is a Quark model that Momo makes.
I really like the look of this wheel... pretty stealthy, flat bottom (but not too crazy) and nice thickness. Problem is that the wheel is made out of polyurethane with leather inserts. I wasn’t liking the feel of the polyurethane on this wheel, which is a huge deal for me since the steering wheel is your most direct connection to the car that you’re constantly in contact with.
Recently, someone here on the forum asked me about the seats I’m using for my Nova. I forwarded the link to the web site for the craftsman (Marek) that did my seats. I noticed that he had a new website that had a gallery of a bunch of his work/projects and I noticed that he recovers steering wheels. So, I reached out to Marek and discussed what I was looking for. Marek suggested we buy the Momo wheel and recover it in the same leather that he used to cover my seats. He also said he could add a stripe at the 12 o’clock position, and could stitch it together using the same red thread he used on my seats. He finished the project this week and the wheel is currently in transit to me, but he shared a couple of pictures with me. I can’t wait to get it and see/feel it in person. Let me know what you think. I’ve also included a picture of my seats as a reminder.
2017 Camaro ZL1
EVIL SS (08-08-2020), Goosesdad (08-09-2020), syborg tt (09-05-2020)
Old 08-09-2020, 08:49 AM
Gmachine1911's Avatar
Perfect! Nice stitch-work!
Shane
#theanchorholds
Link to my 68 Camaro build thread:
https://lateral-g.net/forums/showthread.php?t=56387
Link to my 67 Nova build thread:
https://lateral-g.net/forums/showthread.php?t=57769
Old 08-09-2020, 01:57 PM
shelteredV's Avatar
shelteredV shelteredV is offline
that looks great, he does sweet work.
Old 08-22-2020, 07:02 AM
We got the clutch issue resolved - new Monster clutch fit perfectly, shimmed the slave cylinder to Monster’s spec, and got the bell housing aligned properly with the help of some offset dowel pins.
Motor and trans installed. Kurt also made a custom bracket to mount the Dominator ECU up under the dash in a location that allows decent access to the various connectors that plug into the ECU.
I provided Kurt with template for additional wires and pin locations for each that needed to be added to the Dominator wiring harness (e.g., output for PWM control for fans, input for A/C compressor turning on, etc) as well as the digital dash wiring harness (turn signals, oil temp, power steering temp, high beam indicator, virtual switch for driving lights, etc.). Guys got most of those patched in as well.
Rear bumper also polished and hung. We welded the mounting brackets to the back side of the bumper so no exposed bumper bolts. Tail lights in this picture are just for test fitting, they’ll be pulled out, lenses removed and painted black to match the bumpers and the rest of the trim.
Great to see meaningful progress each week!
2017 Camaro ZL1
EVIL SS (08-22-2020), Goosesdad (09-06-2020), syborg tt (09-05-2020)
