Old 10-25-2019, 05:07 PM
NAPA 68 NAPA 68 is offline
WOW........that blower lid is up there! Is the plan your trademark cowl hood? Enjoying the build as always.
Old 10-27-2019, 10:00 AM
RSNAKE's Avatar
RSNAKE RSNAKE is offline
Mark, are you using any electronic traction control? If so, which system?
I am wondering if the Lingenfelter LNC-2014 RPM Limiter Timing Retard Launch Controller GM Gen V DI Engines LT4 LTI L86 L8 will work with the Davis system and the LT5?
1966 Twin Turbo 526 Hemi Belvedere
facebook.com/northernbel
Motor Trend Northern Bel video
1967 C10 LT5
Old 10-27-2019, 10:29 AM
Stielow's Avatar
Stielow Stielow is offline
I don’t use traction control. I do it the old fashion way... with my foot.
Stielow Engineering
The Following 3 Users Say Thank You to Stielow For This Useful Post:
kwhizz (10-27-2019), RSNAKE (10-27-2019), will69camaro (10-27-2019)
Old 11-01-2019, 05:09 AM
Stielow's Avatar
Matt is doing a great job on the sheet metal. It alway amazes me the you buy a rust free California car and all the stuff that needs attention. Car had sat for years and was in primer. 95% solid but it the last 5% that eats all the time.
Stielow Engineering
kwhizz (11-01-2019)
Old 11-01-2019, 07:16 AM
JD67SS's Avatar
JD67SS JD67SS is offline
Is Sled Alley doing the paint, or are you having Dutchboys shoot it?
JD
Old 11-01-2019, 07:21 AM
Stielow's Avatar
JD
Still getting quotes
Stielow Engineering
Old 11-02-2019, 02:44 PM
Stielow's Avatar
Clears the hood!
Stielow Engineering
The Following 5 Users Say Thank You to Stielow For This Useful Post:
fleet (11-03-2019), kwhizz (11-03-2019), NAPA 68 (11-02-2019), Sonar Chief (11-03-2019), waynieZ (12-09-2019)
Old 11-04-2019, 08:22 PM
JB400's Avatar
JB400 JB400 is offline
https://www.hemmings.com/auction/1969-chevrolet-camaro
The Following User Says Thank You to JB400 For This Useful Post:
kwhizz (11-05-2019)
Old 11-05-2019, 07:24 PM
randy randy is offline
Did you ever run a icebox or no real need? Also what front and rear spring rate have you been running ?
Old 11-06-2019, 03:30 AM
Stielow's Avatar
I run a big intercooler with no issues. Iceboxes are more of a drag race thing.
For rear spring rates I like 200 lb/inch with the DSE set up. Ok for the street and Ok for the track. A lot of the Goodguys AutoX crowd have moved to around 400 lb/inch. If you want to do well in AutoX then make the car real stiff.
Stielow Engineering
