Old 04-30-2024, 10:19 PM
camcojb camcojb is online now
Nice work!
Old 06-02-2024, 10:41 PM
1_Car_Guy 1_Car_Guy is offline
Entry 21: 6/2/2024
Finished up plumbing the fuel lines this weekend. I used line separators which kept everything tight and tidy - pretty proud of how it all turned out. All that's left to do now is to take everything apart and do very minor adjustments, run everything over with scotch brite and blow out the lines. I also need to vent the fuel tank...
Tanks Inc. mentions that the vent filter needs to sit at least as high as the filler neck opening. I mean, unless I'm crazy there's really only one practical place anywhere near the ass end of these cars where that's even possible...curious where other second gen guys run their vent.
Mounted the regulator high up and away on the firewall - sure is nice not running heat, a blower motor or A/C...so much freedom.
I also picked up the Detroit Speed steering shaft kit for the 1 inch 48 spline tilt steering column. I was going to splurge for a flaming river steering column but decided to refurbish my original tilt column and re-use it instead.
Car funds are basically tapped once I wrap up fuel and steering so I'll just turn my attention towards next year. I plan on picking up the Ls7 / T56 engine / trans. package from Blueprint next summer. It's absolutely crazy to me that that is happening this time next year. Blows my mind that my dream is slowly unfolding and materializing.
The Following 3 Users Say Thank You to 1_Car_Guy For This Useful Post:
camcojb (06-02-2024), fleetus macmullitz (08-14-2024), Goosesdad (08-17-2024)
  #43
Old 06-02-2024, 11:35 PM
Nice and tidy.
Old 06-03-2024, 07:46 PM
Congrats! You're doing good work and your dedication is impressive.
camcojb (06-03-2024)
  #45
Old 08-13-2024, 09:37 PM
Entry 22: 8/13/2024
Fuel is essentially done. I ended up venting the tank using a roll over valve.
One annoying thing I have to point out about the Tanks Inc. EFI Tank kit for my car: It's a generic kit for 74 through 81 Camaros and Firebirds. It came with a 30 degree filler neck. There is no way that is supposed to come with the kit for a 74 through 78 Firebird. It clearly comes out several inches too low. Luckily, even though I bought the kit back in 2017 - Tanks Inc. sent me a 45 and 60 degree neck at no charge. The 45 degree neck is the one I needed.
I also picked up an Ididit steering column and used Detroit Speed's lower steering shaft. Super nice set up. Photo of that.
Finished the corners this past weekend. Went with the Wilwood Superlite kit (P/N 140-8921) up front. Out back, the Dynalite rear kit (for a Big Ford flange) (P/N 140-2115).
I also placed an order with Weld Wheels. Lead time is 6-8 weeks. Ended up custom ordering a specific offset for the front. 15 x 11 in rear and 18 x 10 in front.
Car is getting manual brakes and a hydraulic clutch and I want to use three canisters on the firewall - so some more firewall work to do over the fall when I mount pedals.
Been a pretty productive summer so far. Over the winter I'll plumb the brakes and finish the firewall / pedals etc. Might turn my attention to the dashboard - and get this thing back on the ground. Will be awesome rolling it out to see the stance once the wheels show up.
The Following 4 Users Say Thank You to 1_Car_Guy For This Useful Post:
camcojb (08-13-2024), fleetus macmullitz (08-14-2024), Goosesdad (08-17-2024), WSSix (08-20-2024)
