Old 01-11-2020, 07:54 AM
Stielow's Avatar
Stielow Stielow is offline
Originally Posted by JON Q View Post
Mark, your new website is very cool!
Thanks. Jody did it. Looks cool.
Stielow Engineering
Old 01-11-2020, 07:59 AM
vdrivinmike's Avatar
vdrivinmike vdrivinmike is offline
Love the rendering; looks fantastic.
Mike F
"ssmike" on PT.com
Old 01-11-2020, 02:36 PM
kwhizz's Avatar
kwhizz kwhizz is offline
Originally Posted by jon q View Post
mark, your new website is very cool!
x 2...………………….
Old 01-16-2020, 05:19 AM
Stielow's Avatar
Working on the dry sump tank science project. This gets hidden in the passenger fender in the cowl area.
We run -8 lines off the valve covers to a -10. That runs to the top of the dry sump tank. Then the dry sump tank vents through a Mann and Hummel Air oil separator. The 5/8 line coming off the air oil separator runs to the induction tube.
The tall cylinder mounted to the dry sump tank is the transmission expansion tank. I run the vent line off the trans to the bottom of that tank. During open track days I have seen the transmission push out fluid when it is hot. Makes a mess. So now we add an expansion tank. Fluid get hot gets pushed into tank then drains back into trans when it cools.
Stielow Engineering
Old 01-16-2020, 06:18 AM
dontlifttoshift's Avatar
We duplicated that setup on a LT4 after seeing it on Gunner.....which way is the arrow pointing on the Mann Hummel separator?
Thanks for taking the time to post this. I know people like pictures, but the technical side of things is what interests me about anyone's build threads.
Donny
Old 01-16-2020, 06:36 AM
ScotI ScotI is offline
This...
The explanation behind is so appreciated. It helps those that aren't 'in the know' get a better idea of how things can be improved. Of course pics also help see details that push others builds to new & better levels of execution.
Old 01-16-2020, 07:38 AM
Stielow's Avatar
Default Camaro LT5
Originally Posted by ScotI View Post
This...
The reason the tank has the extra volume added is because the oil level has to be checked with a dip stick. To make the system less sensitive to oil level we add an extra 2 quarts to the system.
This is the 4th car we have done this modification to and it works great. The only big issue is if you have an issue with it to service it.
Now I pressure test all tanks and hoses prior to assembly. Save a lot of time to fix it before it is buried in a fender.
Stielow Engineering
Old 01-16-2020, 03:49 PM
clill's Avatar
clill clill is offline
Ask him how he knows this.
Old 01-16-2020, 07:33 AM
Stielow's Avatar
Stielow Engineering
Old 01-22-2020, 11:31 PM
CarlC CarlC is offline
Regarding the induction tube attachment, understanding that Mann Hummel -10 line should be downstream of the MAF, have you found there to be an better attachment angle/arrangement? A "T" with the -10 hose connection at an angle to the airflow + away from the short radius bends? I'm finding a larger fresh air vent is needed to help keep the oil clean vs. the stock 3/8" lines.
http:www.vaporworx.com
