Old 10-10-2020, 06:21 AM
Stielow's Avatar
Stielow Stielow is offline
This car has some Dakota Digital stuff on it.
Matt put all the modules on one removable panel so it can be serviced. Some lessons learned from the Riv and Blazer.
Stielow Engineering
Old 10-10-2020, 05:27 PM
jmac jmac is offline
Man this car just continues to amaze me. The tech that you're integrating in to this car is awesome. It's going to be just like a newer modern car. TPMS, climate control, cruise control, it's all in there!
What temperatures are you monitoring with all those BIM modules?
Why are you using the GPS module? Can't you get speed and all the engine info right from the LT wiring harness?
Please share with us your reasoning.
Thanks again for always sharing!
My 1967 Camaro
Old 10-19-2020, 06:43 AM
thedugan's Avatar
thedugan thedugan is offline
Love this setup. Where does the mount go behind the dash on a first gen.. I might need to see if they will make more of these and sell them.
Doug L.
68 Camaro RS/SS Conv. LSA/T56
67 Camaro RS LS2/T56 "NutKse"
Old 11-12-2020, 02:45 PM
Blackhawk's Avatar
Blackhawk Blackhawk is offline
I love seeing all of the thought and experience behind the details that go into your builds to improve serviceability and performance!
Is the 2 gallon peterson tank you start with on your builds their off the shelf 6x19.5 or is it made with custom dimensions?
Old 11-12-2020, 02:46 PM
Stielow's Avatar
Custom but close to the off the shelf part
Stielow Engineering
Old 11-12-2020, 04:25 PM
Blackhawk's Avatar
Thanks, I thought it looked a bit wider than 6". I take it the extra volume is from that boxed out portion that mounts to the firewall?
Very neat solution by the way, I'm leaning towards trying the same thing after seeing how crowded the engine bay is otherwise.
Old 11-30-2020, 04:46 PM
Stielow's Avatar
Some random photos. The last photo was from another project, but I thought it was funny.
Stielow Engineering
Old 11-30-2020, 04:47 PM
Stielow's Avatar
Stielow Engineering
Old 11-30-2020, 06:53 PM
jeff71 jeff71 is offline
Mark, are those Cup2’s?
Old 12-01-2020, 05:18 AM
Stielow's Avatar
The tires are BFG Rivals
Stielow Engineering
