Don't know if it was the scatter shield or the aftermarket shift arm or combo of both but there was not near enough clearance for the shift fork to move back. Had to spend a few minutes with a die grinder.
I opened the new body mounts for the first time today. One mount on each side would not fit. The hole in the frame was a lot smaller on that one mount. I don't know if if it was a misboxed product but I did not want to wait a week to get the right part. My first thought was to trim the frame out to match the other holes but I did not want to cut the powder coating. I then decided to cut the rubber down. I think I cam up with a pretty cleaver way to do it after brain storming a little while.
I first measured the size of the old original bushing. I then found a 3/8 fender washer that was close to the size but still apox .075 big. I took a long 3/8 bolt and nut and tightened it all together. I then chucked it up in the drill press. With a file I cut the washer down to the exact size I wanted to cut the rubber to. Now I had a perfect guide. I took the long 3/8 bolt with my new resized washer and another washer on the back side. I centered the guide washer on the rubber bushing and tighened it snug enough to hold. Chucked up in the drill and carefully used a razor blade to trim the rubber pefectly to the size of the washer. Hear is a cut one next to an uncut.
I wanted to be really close when setting down the body. So I used two plumb bobs. One front and one in the oppisite rear corner. I little scooting around on the jack and the frame was exactly where I wanted it.
