Old 12-02-2005, 01:29 PM
drmrman's Avatar
drmrman drmrman is offline
I love it! *Perfection*!
drmrman
Old 12-02-2005, 02:19 PM
TravisB TravisB is offline
you and Troy are the only ones I have ever seen wiht unwelded rim shells.....thats cool that troy is hooking you up like that! I assume there be a test fit then final weld??????
we have tried to get unwelded wheel blamks from several wheel companies to no avail.......
Kenny Davis Hot Rods
Old 12-02-2005, 02:51 PM
syborg tt's Avatar
I learned long ago it's not what you know it's who you know. I can't tell you how much i appreciate Troy's help and Billet Speciaties help with these wheels. The good thing is the Billet Specialties is only 15 minutes from my office.
marty-mj
Old 12-02-2005, 02:59 PM
I could see how that would be very nice.....
Old 12-04-2005, 08:39 PM
syborg tt's Avatar
12-03-05 Update
Dave mounted the air system while I was on Vacation and it looks exactly like I wanted to look.
It's mounted on a tubular chassis so it will remain on the chassis when the cab and the bed are removed
Here is the top view
marty-mj
syborg tt's Avatar
You can see my idea for the bed and I couldn't be happier with it.
This is the frame work that will support the new bed floor.
marty-mj
Old 12-04-2005, 08:40 PM
syborg tt's Avatar
Brakes - What can i say. Precisions Brakes did and awesome job on them. This is the final front brake caliper and it is an exact match for the rear caliper something we need it we are going to show the truck.
Rear Brakes going on.
marty-mj
Old 12-04-2005, 08:41 PM
syborg tt's Avatar
The exhaust is almost finished all we need to do is cut the end of the tailpipe.
You can see the transition from the round to oval tailpipe. I think Dave did and incredible job joining the two pieces.
If we need, we will now be able to remove the mufflers.
marty-mj
syborg tt's Avatar
Moving on to the front suspension. I installed the Bear Tracker Tie Rod ends and sleeve. What a nice piece.
A quick picture of the trans pan installed and check for clearance issue's
marty-mj
Old 12-04-2005, 08:42 PM
syborg tt's Avatar
I saved the best for last "the Wheels". The tool that we used for mock up was perfect. It nailed the offset on the front wheels on the first try. I can't wait to do another truck.
Here is what the truck is going to look like when the air suspension is deflated.
There is a minor vlave stem clearence issue which can easily be resolved with a set of low profile valve stems from Weld Wheels.
No clearence issues on the rear wheel.
we decided to go with the sticky outy look on the wheels.
No really once the tires are mounted we will narrow the rear diff.
That's it for this week. I've got a bunch of parts to order and I need to get the wheels back to Billet Specialties so they can weld them up for me.
marty-mj
