Originally Posted by novanutcase
Doug,
Have you had a chance to run the car around any corners? How did it handle?
John
We have but haven't pushed it hard because we have not dialed in the suspension.
Sadly Wayne Due really screwed up the frame! We had to redo the front a-arms because the way he set it up it didn't allow for proper geometry.
The back....where do I start? We got the alignment as close as possible with a plumb bob, strings and levels. Our next problem is how to get it on an alignment rack. We are finding out the alignment shop needs to be able to attach their laser jig onto the wheels in order to do a four wheel alignment. They are saying they can't do this because the wheels are tucked up inside. Right now it looks like the back adjustments are maxxed out. So now we are thinking if we have to do some more adjusting we may have to change the pickup points on the suspension to get it aligned properly. Another issue that really upsets me is the way Wayne designed the rear end. There is no way to run exhaust out through the back. You don't know how many times I have thought about ripping out all the rear and doing a straight axles and 3 or 4 link
Also we probably need to change the spring rates the ones Wayne provided were all wrong. After all the money I spent with him I felt I was definitely shortchanged. To add insult to injury he is no where to be found to confront him with these issues
Sorry for the rant
Doug
