Go Back   Lateral-g Forums > Events > Track and Driving Events
Old 07-26-2011, 03:52 PM
Bow Tie 67's Avatar
Bow Tie 67 Bow Tie 67 is offline
It is a 2010 Cadillac SRX twin turbo fan. It is pulse width modualted fan so it has to be controlled by a engine control module. So, I can only run it as hard as I needs to given the load on the cooling system or A/C. It is the most powerful single fan in the production at GM. 850W or it needs a 70 amps to run at full power! A ZR1 Corvette cooling fan is a 450W for reference.
Mark
Ok, thanks for the info, which brings up some other questions. Do you have a custom / stock GM reflash in your GMPP ECU to control the fan? if so which one? What is the output of your alternator?
I just bought an AFCO dual pass radiator due to my high temps at AutoBohn. I was planing on reusing my 4th gen dual fan assy but it does not fit well. So I'm scrambling to come up with an OEM solution for a fan.
Thanks again,
Matt
Matt
Project: " Chain Reaction "
A.K.A. " BIG " by wife, biatch in garage.
1969 RS Camaro, L92 T56, Chassisworks sub, Quadra-Link, Bear, Ford 9".
