Old 02-08-2012, 07:55 PM
SRD Art's Avatar
SRD Art SRD Art is offline
Now that the hitch was in and tied the rear frame rails together, the big highlight of today was pulling the body. Woohoo!
There are 12 body mounts on the wagon, 10 of them are bolted in, 2 are pushed in. 7 of the 10 bolts came out easily. 2 of them, both 4th back from the front, were so rusted that there was pretty much nothing left of them. I'm surprised they didn't just fall out of the car. number 3 bolt on the driver's side froze up after a few turns. Then it started spinning freely. I thought the bolt broke but actually the tapped plate started spinning inside the body and karate chopped through the floor sheet metal. I cut around it to peel up the sheet metal and spot welded the plate back down. After that and a bigger impact gun it came right out. Notice the torn sheet metal at the top of the photo, wow.
We have a rolling electric winch on beam track that spans the shop. Using a heavy tow strap I found the balance point in the rear door openings and pulled it up. I wish I could tell you guys how exciting today was. After fixing a couple things and some fabrication to beef up the frame it will head to the sandblaster. Once it's back and painted it's all bolting on parts from here on out. This was a huge milestone and I'm totally stoked. And yes, I know the front tires are on backwards.
-Ben, Your friendly neighborhood Rendering dude, PM me for info!
My SRD Renderings Instagram page
My SRD Renderings Facebook Page
Pumkinator '79 Cutlass Wagon Build
Old 02-08-2012, 08:18 PM
daemon2's Avatar
daemon2 daemon2 is offline
I enjoy seeing updates on this build, great progress!
Daemon2
Old 02-09-2012, 05:17 AM
Macbuick's Avatar
Macbuick Macbuick is offline
Originally Posted by SRD Art View Post
The interior will be black with a splash of orange and silver accents. I plan on painting the cage silver too.
With black interior, wouldn't it be nicer to paint the rollcage black ?
Dark painted rollcages are always way more subtile and discrete than light ones....
see your drawing with black tainted windows and imagine the silver rollcage flashing behind the windscreen
[SIGPIC][/SIGPIC]
72 Skylark & 68 Pontiac Catalina+ 71 El Camino
Old 02-09-2012, 07:05 PM
SRD Art's Avatar
Originally I wanted the roll cage to standout and the silver paint will also match the silver accents on the dash and door panels. But, you're right, I think black is a better choice, silver may have stood out too much.
Old 02-09-2012, 07:08 PM
SRD Art's Avatar
Progress for today...
I always stay as late as I can to work in the shop so most everyone was gone when I pulled the body off yesterday. I feel like I spent half of shop time today explaining over and over what I plan to do with the frame.
I did strip off all the brake and fuel lines and unbolted the rear shocks. The driver's side rear spring cup was torn, so I got this welded up too.
Then I addressed the retarded G-body trans cross member. For those that own these cars understand my pain because the g-bodies are set up for only single exhaust. Unless you can fab up something you're going to be out about $150+ for a cross member with a driver's side exhaust tube clearance. I looked at a couple aftermarket and a few custom dealios on the net and decided that the easiest and cheapest thing to do was modify mine.
Quick and dirty, the hand held plasma cutter hacked the thick tube easily. Unless you have a surgeon's steady hands, which I clearly don't , you end up with something like this.
A couple minutes with the grinder smoothed it enough to weld. I think with keeping about 1/2" of the vertical sides it should be structurally strong enough to hold the tail of the tranny. To box and finish it I grabbed a scrap of 18 ga sheet, bent it to the shape of the void and welded it on. I could've stopped there but I wanted it to look like it was supposed to be like this from the factory so I took some time and metal finished it instead. Once it's painted it should look like it was formed that way. Here are a few shots from different views. I'm pretty happy with the end result.
Tomorrow I start boxing the frame!
Old 02-13-2012, 02:01 PM
SRD Art's Avatar
Someone on another forum asked if I thought the trans crossmember was strong enough the way I modified it. Really, with the front motor mounts holding up the bulk of the weight, there isn't much weight on the trans cross member. It's almost more like a resting spot to bolt down the trans. Just to be safe I had my good friend Jay stand on it for me. It flexed about 1/8" but at 260 lbs. Jay probably weighs twice what a TH350 does.
Old 02-13-2012, 02:05 PM
SRD Art's Avatar
Updates...
I went to the local metal supplier and bought some more 1/8" sheet stock and some sections of 1", 3/16ths wall tubing from the scrap area. 37 lbs total at .79 per pound.
First job was tack weld the trans cross member nuts to the member so that I don't need a wrench anymore to install the bolts. I then straightened the frame rails where a floor jack had bent them up a little and prepped them for welding by grinding the surface rust off.
A design cue and one issue to deal with here- Notice I put the sheet stock in the brake to bend it slightly, matching the design cues from the front frame rails. Just a little added visual touch that only took a couple extra minutes.
Also the body mount area needed some working. It's curved at the top and you need to leave it open so you can get a body bushing up in there. After welding on the longer sections, I made the smaller body mount sections using the table mounted plasma cutter. Once they were tacked into place it was fairly easy to get them to contour to the curved upper rail.
I'll have the open gaps where the factory boxed rails meet mine boxed in tomoorow, and then it's on to building some bracing into the frame...
Old 02-13-2012, 05:54 PM
Nice work its looking good.
Old 02-16-2012, 09:36 PM
Biggunns Biggunns is offline
I started reading this and realized I've seen your Cutlass in the parking lot of the SS Walmart, and to top it off I'm the director of admissions at UVU, such a small world. I think it's awesome you are creating such a unique car, I have a 2wd lowered Tahoe in Utah and everyone thinks I'm crazy. Keep up the good work.
Old 02-17-2012, 07:15 AM
SRD Art's Avatar
Wow, it is a small world. I live in the Ranches @ EM. If you drive the Tahoe a lot I've probably noticed it, a lowered truck looks very refreshing after seeing so many lifted diesels. I have a 2 wheel drive 77 Suburban that will be getting dropped 6" after the wagon's done. I also have a '76 Suburban that's lifted and I wanna sell it.
If you get a minute stop by the street rod shop in the automotive building some time and chat. I'm usually there from 9 am to 2 pm.
