Old 02-21-2013, 10:56 AM
chr2002ca's Avatar
Great updates Dale. Thanks for continuing to share the great details and photos. I'm sure you're happy to finally see that Magnum up in there and sitting on that crossmember. Not an easy job whatsoever. I'm going to be starting that exact same job in less than 2 weeks, so I appreciate everything you've shared so far.
My "clutch fingers to block measurement" is estimated to be just slightly less than yours, and my bellhousing depth a half inch more than yours, so I'm thinking I'll need to use that ZR1 slave also which has a lower profile than a standard LS slave. I have 2 'quick' questions for you.
1. When you compressed the slave cylinder and measured from the face of it to the mounting face of the transmission, do you remember what measurement you got?
2. You mentioned the ZR1 slave has some special plumbing notes. Is it necessary to use that hard line that comes with it? I was hoping to just plumb a soft line from my MC directly to it. Any plumbing notes you could share would be great.
I'm jealous of that jack you used. I need to find me one of those!
Thanks again,
Chris
Chris Robinson
Old 02-21-2013, 11:14 AM
Sieg's Avatar
Sieg Sieg is offline
Thanks again,
Chris
Chris, I'll lend you a hand and it's only $80!
http://www.harborfreight.com/450-lb-...ack-39178.html
Old 02-21-2013, 02:29 PM
chr2002ca's Avatar
Perfect! And that right there is why I love this forum. Thanks Sieg! The local Harbor Freight has 3 of them in stock. I'll snag one this weekend. Given my luck, I'll probably need it 5 times over the next 6 months.
Chris Robinson
Old 02-21-2013, 02:54 PM
Sieg's Avatar
Welcome! Things like this jack that seldom get used are what I love about Harbor Freight. Hopefully you only use it once.
Old 02-21-2013, 08:54 PM
DaleTx's Avatar
DaleTx DaleTx is offline
Thanks again,
Chris
Thanks Chris... It felt great to finally get the T56 bolted up
I did purchase the transmission jack from Harbor Freight like Sieg said. The transmission jack also works great for removing and installing the fuel tank. It’s a nice tool to have around.
Here's the answers to your questions:
1. The measurement from the face of the bell to the compressed throwout bearing was 4.280". I ended up with 0.125" clearance between the clutch fingers and the face of the compressed throwout bearing.
2. For the plumbing I ended up using the hard line that came with the GM ZR1 throwout bearing. The plumbing that goes into the throwout bearing has a special O-ring quick disconnect fitting that is retained with a clip. I’m not sure if you can substitute that with a soft line… there are no threads to screw into.
On the other end of the hard line there is a black plastic female quick disconnect fitting that accepts a male fitting with an O-ring. I ended up having a custom line made that goes from the clutch master to the female fitting.
What I found out is that there are two different style male quick disconnect fittings… one style for 2004 and older throwout bearings, and one style for 2005 and newer. The GM ZR1 throwout bearing (pn: 24237569) takes the 2005 and newer fitting. Of course the first one I bought didn’t fit and that’s how I found out!
I ended up buying a custom line from Mcleod Racing. There is a technical sales guy there named “Billy” and he was very helpful. If you talk to him he will set you up. I’m due to receive the line tomorrow (Friday) and I will post up a picture of the set up. Hopefully everything will fit this time around.
Here is a shot of the ZR1 throwout bearing with the hard plumbing and quick disconnect fitting
Here is a shot of the male quick disconnect fitting that didn't fit. It looks like it would fit but was 0.030" to big!
I should receive the new line from Mcleod tomorrow. I'll post a picture if I get it.
Hopefully this info will save you a little grief.
"If you wait, all that happens is you get older"
Mario Andretti
69 Camaro-Nutter Racing Engines/427CI LS2 sleeved/LS7 CNC ported heads/Custom cam/T&D 1.8 rockers/Manley crank/Manley H-beam rods/Weisco pistons/NRC Pro Series dry sump/Kooks/NA,92 octane,11.5:1- 672HP @ 6,900RPM, 566TQ @ 5,500RPM
Build Thread- http://ls1tech.com/forums/generation...ine-build.html
Old 02-21-2013, 10:50 PM
frankv11's Avatar
frankv11 frankv11 is offline
I bought same coupling a while back from them , just had to get crimped once positioned. Don't know if your running a remote bleeder line but it would save you a ton of headaches if you do. Can find them all over eBay
Old 02-22-2013, 12:05 AM
Todd in vancouver's Avatar
Todd in vancouver Todd in vancouver is offline
Always good to see someone else from the Pacific NorthWET!
Nutter does some engines and dyno's them over at Jim Preston's some times... and he used to build Preston's drag motors...
Where are you in the PNW??
Originally Posted by DaleTx View Post
Lol... nothing like 4 straight months of gray sky's and drizzle. I'm in Vancouver. I run my car at PIR. Might have to check out some tracks up north sometime.
Nutter is a great guy to work with, he's told me a few stories about his drag racing days... do you know him?
Originally Posted by Rybar View Post
Again very nice motor Dale, you in Vancouver, BC, Canada or Vancouver, WA?
Originally Posted by frojoe View Post
Rybar and I are also suffering the dismal Pacific NorthWet blues. Great car and nice build!
Just finished reading your thread and you've done some really nice work. I guess I better get my butt in gear and transfer my posts over to here from PT on my project.
It's amazing just how many guys there are with some really awesome builds around the PNW area. Hopefully there will be some local events coming up where I can see these super cool rides and meet some of you locals. It seems like the events are South but if/when we see some good weather I'm hoping there are some posts for local events. I'd really like to see your car and some others before I embark on my LS conversion.
Todd in Vancouver, Canada
'67 Camaro SS
How hard can it be?
Project Obsession
https://lateral-g.net/forums/showthread.php4?t=40384
Old 02-22-2013, 09:01 AM
Sieg's Avatar
Yes you should get your build over here!
I've noticed Lat-g is starting to get a collection of PNWet members, maybe a trackday at The Ridge or Oregon Raceway? Indoor kart event tied in with the PDX Roadster Show, or?
Old 02-22-2013, 08:45 PM
DaleTx's Avatar
Thanks Frank… I did end up installing a 4ft remote bleeder line.
Thanks Todd
Definitely post up your project here...
That would be great to meet up with some of the PNW & Vancouver B.C. guys in the near future. We’ll have to work on that one and find a show somewhere mid way
Sieg… Count me in, I would like to meet some of my fellow PNWet neighbors!
A trackday at the Ridge or Oregon Raceway would be great!
Mario Andretti
Old 03-20-2013, 07:31 PM
DaleTx's Avatar
Default Tunnel mods
I ended up raising the tunnel 7/8” in the back and 1-1/4” in the front. After installing the transmission there is about ¾” plus clearance all around between the transmission and the tunnel. This should be enough to prevent rubbing, and allow for some airflow.
First I fabricated the tunnel and added a gusset where the console mounts and where the shifter boot mounts.
Next I secured the weldment to the tunnel with sheet metal screws to hold everything in place for welding.
Next I welded the tunnel all around from underneath the car ...not a fun job!
Next two pics show penetration from the weld underneath.
Then I welded the tunnel all around from inside the car, and cleaned up the welds with a little sanding.
Next I painted the tunnel and re-installed the transmission
Mario Andretti
