Old 01-20-2013, 02:42 PM
coolwelder62's Avatar
Default Scott Mock/vrp New 2013 Sub Frame Design
As the heading say's I have have a new sub frame Design to 2013.This will be an upgrade for those of you wanting an even more Professional Looking Design.I have Added new Mandrel bent 2x4 mail rail's,CNC Plasma cut flat part's,New stronger cross member design,A new upper A-Arm mounting plate W/more coil over shock ajustment.A New sway bar mounting tube design,All new lower A-Arm surport mount's,New frt. body bushing mount bracket's w/alinement hole's,Punched & dimple die'd lighting hole thur-out the design.An all motor mount & new tran's crossmember design.All material will be P/O tubing or plate.This is mandrel bent rail frame only.
Old 01-20-2013, 03:16 PM
Bryce Bryce is offline
where are the pictures
Old 01-20-2013, 03:46 PM
Sorry It took for ever for photobucket too work.
Old 01-20-2013, 03:56 PM
Understand We still have a ton of work left too finish it out.This one will be going under My son's Kevin's Camaro.He is doing a lot of the work on this first one.It look's like this one wil be about 10# lighter & alot stronger than my Org.design.It should look as nice as the best sub frame's on the Market.
Old 01-20-2013, 04:14 PM
eric1967 eric1967 is offline
Looks really good
Old 01-20-2013, 05:15 PM
MODO Innovations's Avatar
That looks really good Scott. Can't wait see what's next.
Shannon
Modo Innovations
940-391-9002
Old 03-31-2013, 06:35 PM
syborg tt's Avatar
Quick Question
I am aware you offer 3 stages of chassis. Do have details posted somewhere
marty-mj
Old 03-31-2013, 07:35 PM
Quick Question
Here are the detail's For the New Design requested.StageI-$4450.00 kit includes bare frame,splined sway bar & arm's,Dropped bolt on steering arms,Sway bar end link kit,New style flate trans crossmember,Shipped to a freight dock near for customer pickup.StageII-$4900.00 same I w/ridetech coil over's.Stage III-$6850.00 same I & II w/ new GM C-6 componet's,Modded C-6 spindles,New Rack & Pinion. Options,Drilled sway bar arm's $75.00,Single ajustable coil up grade $100.00,Triple ajustable up grade $750.00,Quick steer 15:1 rack N/C.Ceramic coated LS header's $875.00.
Old 04-02-2013, 07:35 PM
bret's Avatar
bret bret is offline
Supporting Vendor
Scott...nice front suspension...it's got all the right stuff...very proud to be associated with your efforts with our shocks...go, go, go!
Bret Voelkel
President
RideTech
Air Ride Technologies, Inc.
Old 04-03-2013, 05:51 AM
Thank's Bret.The ride tech shock's are work's of art that work as well as they Look.
