Old 01-31-2014, 12:21 PM
glr0212 glr0212 is offline
Default 1969 Camaro RideTech tru-turn review/fitment w/pics
Wanted to give my 2 cents (earned the hard way) on the ridetech tru-turn and the ability to put a 10” 275 tire on a 69 Camaro.
The short version is it doesn’t really fit.
My setup is probably pretty common for people buying this system.
  • Stock subframe
  • ½” Drop body bushings
  • Full ridetech front suspension with the muscle bar
  • 18x9.5” front wheel w/ 6.25” backspace
  • 265/35 tires
The car has been fully aligned per the Ridetech's specs.
Here is how well it “fits”
***** I added back in several of the key pictures on this thread that disappeared when third party hosting was dropped. Mine is the green car. The blue car is the car done by a ridetech guy later in the thread. The yellow fender is the modification done for a custom car to make larger front tires fit.
Last edited by glr0212; 10-12-2017 at 11:51 AM. Reason: tire size - added pictures
Old 01-31-2014, 12:30 PM
Default part 2
As you can see it really doesn’t fit well. The fender sits on tire when the wheel is turned.
What you can’t see is the rear of the tire hits the frame rail long before I reach lock on the steering wheel. I would probably have to do a 3 point turn when taking a right at a stop light if I left it this way.
I’ve said in another thread and will say it in this thread - I don’t see how you stuff that much tire into the fender well with a stock subframe. There just isn’t enough room to make it work.
The only options I have at this point are:
1)New wheels and smaller tires upfront
2)Raise the car 0.5”-1” and hope I can clear the fender and just live with the mile wide turning radius
With option 2 I think I still may have to get stiffer springs in order to keep the tire from riding up into the fender while turning over a large rise in the road (aka turning into a parking lot)
Old 01-31-2014, 12:32 PM
Default 3
I am not posting this to flame on ride tech. I think they make a nice product. It goes together well and probably handles great. On the other hand it is not a great solution for fitting larger tires into a 69 camaro.
I just wanted to post another viewpoint besides “yeah, everything fits right in there with the right backspacing” In my experience, it doesn't fit. I have no room to give on either the front or back side of my wheel.
Old 01-31-2014, 01:34 PM
jlwdvm jlwdvm is offline
I have the same set up as you on my 69 firebird project, except I have solid stock height body bushings. I haven't ordered wheels yet, but already have new Toyo R888 275's for the front. I hope the solution is different back spacing with the stock bushings...guess I'll have to measure and see while crossing my fingers! Thanks for the post
Old 01-31-2014, 01:48 PM
Josh@Ridetech's Avatar
Josh@Ridetech Josh@Ridetech is offline
Hey GLR0212,
I'll be happy to help you figure this out, I just want to check into a couple of things to see what we're working with. I saw up above where you said you used our alignment specs but can you tell me exactly what you have your camber set at? We ran a 275 on the 69 GG/RS Camaro that we just finished. We just need to see where your problem is coming from.
Old 01-31-2014, 03:53 PM
130fe 130fe is offline
Question
Do you think putting "regular" height body bushings on it would help? It might get you some more clearance.
Chris
1968 Camaro SS
LS3/T56
Full of DSE and Holley parts
Old 01-31-2014, 08:19 PM
Regal454 Regal454 is offline
Josh,
How wide and what was the back spacing on the front wheels of the Goodguys Camaro?
Were the tires a 275/35/18?
What was the camber setting on the alignment?
I'll be ordering a set of wheels soon for my Ridetech equipped 69 Camaro soon so any help would be greatly appreciated.
Old 02-01-2014, 01:41 PM
Hey GLR0212,
I posted the alignment specs above. What is the ride height on the GG camaro? Measured at what point?
Old 02-01-2014, 02:10 PM
Rod P's Avatar
Rod P Rod P is offline
get rid of the half height body bushings, that tucks the frame higher into the body
and that wheel backspacing (6.25” backspace) is more for a scott mock style frame that has the corvette arms
Rod Prouty
My websiteAuto-cross 101
Bangshift Stories
Old 02-01-2014, 02:37 PM
i think we are missing something in communication here.
I clearly do not have room to move the wheels and tires OUT 1/2". The fender is already sitting on the wheel practically. I'll get another picture later to demonstrate this for you.
Also not sure how body height bushings are going to create more side to side clearance in the fender wells.
