Old 01-25-2015, 03:13 PM
Flash68's Avatar
Flash68 Flash68 is offline
I don't see 4" stroke being an issue unless you're consistently running it past 7000 rpm, and even then some will likely debate that.
Street cars like cubes and torque... and this IS a street car, right?
Get the extra cubes while you have the "opportunity"...
2004 NASA AIX Mustang LS2 #14
1964 Lincoln Continental
2014 4 tap Keezer
Old 01-25-2015, 03:20 PM
Sieg's Avatar
Sieg Sieg is offline
You'll spend more time driving the meat of the torque curve than the meat of the horsepower curve......unless you're on a fast road course the majority of the time.
Old 01-25-2015, 05:00 PM
100%
Old 01-26-2015, 02:05 AM
71RS/SS396's Avatar
Exactly why folks should pay more attention to average horsepower numbers on a dyno sheet rather than gawdy peak numbers.
Old 01-26-2015, 07:57 PM
carbuff's Avatar
carbuff carbuff is offline
Given that I've done more autocross events than I have road course events, I could DEFINITELY use the increased torque under the curve to propel the car. That's why I'm focused on doing things with this rebuild that will improve the mid-range torque generated. I'm fighting myself given that I selected the single plane intake for this setup, but I think I can end up with a combination I'll be plenty happy with. Researching engine data for the LS platform is like a drug for me: I'm addicted to learning!
ALl that said, I'm not sure it's worth the risk to step up the stroke from the current 4.000" to 4.125". There is a lot of debate on this topic that I've been devouring the last 2 days, but I'm leaning away from it now and sticking with the known 4.0" combination.
Tim, it was good meeting you yesterday. Glad the weather cooperated and you were able to bring the Camaro out. And if you can find that info we discussed, send it on over.
I'm back in Austin finally, so I hope to make some moves forward this week. I haven't heard back from TEA on the status of the heads. I do need to touch base with TSP and let them know something. I can't really move forward with them until I know what I'll be doing on the heads though. If this combination is going back together, I'll need to specify the pistons to use before any of the bottom end work can start...
Old 01-26-2015, 07:59 PM
carbuff's Avatar
Maybe some other crank company makes a 4" stroke with 2" journal for LS?
Step it up and go for the 1.88 Honda journal.
Where's the ricer emoticon when I need it!!!
Old 01-29-2015, 07:52 PM
carbuff's Avatar
Time for an update...
It's not been a good week, but at least I have more data to make decisions about moving forward. Things I've found this week:
  • The crank needs to be turned (think I already mentioned this). Turnaround time is 3-weeks, but cost is a little less than I was previously told. So it's on the way to ShafTech to turn and re-harden.
  • The clutch I have is an immitation of the Monster Clutch product, made in Mexico. In talking to Monster, the pressure plate I have is problematic, and looking at the disc, I probably need to replace it. So I'm headed down the path of a full clutch and flywheel replacement.
  • Today I learned that the heads are toast. The first phone call I received about them told me that the valve tips seemed to have excessive wear, to the point the shop didn't want to reuse them (which may mean my rockers are toast as well). However, it seemed like they could repair the damage from the shrapnel by welding and milling the heads. About 30m later he called back to tell me the heads had been milled down to 59cc's, which is way too small for what I want to do (deck too thin). So, I have a couple of heavy paperweights now.
I've been shopping the LS forums for options on parts that I might use for the rebuild. One thing Tim educated me on last weekend was that I could use an LS7 block with a wet sump, so I've been looking for one of those. While I was traveling last week, I just missed one for sale in my backyard (30m away) that sold the day before I got back.
Then, in preparation for the possibility of the heads needing to be replaced, I was searching for aftermarket sets of those. I found a great set for sale that I was emailing with the seller about. Danged if he didn't sell those last night, so again, just missed them...
On the positive side... Eric shipped my leaking radiator back to PRC who originally manufactured it, and they agreed to repair the pinhole leak at no cost, other than shipping. So that's one little problem solved.
Also, while everything is apart, I called AGR who made the steering rack I put in the car last year. My PS pump has been making some strange noises. I got an education on pumps and racks, and I have a new pump on the way from them. Hopefully that will take care of that problem!
At this stage, I have a half-formed plan in place. With the additional problems that I've found, I've decided to get my crank fixed by ShafTech and Callies which will allow me to reuse it and my rods. Unless I stumble onto an LS7 block before the crank returns, I will go ahead and reuse my block and build it back as a 405 (4.010" bore / 4.000" stroke). I am continuing my search for a set of heads, but at a minimum I'll buy a set of CNC ported L92's. I could either get the GM CNC version, or have one of the many different shops that do the CNC work do them for me. I am going to call a few of those tomorrow to discuss pricing and lead times...
I'm probably going to get the new LT1-S twin-disc clutch setups to ensure that I don't run into a clutch issue in the near term:
http://monsterclutches.com/2004-2006...eet-gto-clutch
Steve just installed this in his LS / T56 build and seems to like it.
That's it for now. More to come soon...
Old 01-29-2015, 08:10 PM
carbuff's Avatar
One more thing that I learned today...
The likely cause of the valve spring failure was the engine sitting for so long after being assembled. The motor was originally built back in 2007 if I remember correctly. I didn't fire it up until 2013. So there's a good chance that a few valve springs were compressed for 5+ years. It seems that can cause springs to weaken and ultimately fail. Makes complete sense, but not something I would have thought of...
Old 01-29-2015, 08:12 PM
glassman's Avatar
glassman glassman is offline
Hey Bryan, what heads you doing? I didn't see it on the clutch site, but is that aluminum or steel flywheel?
Hang in there bud, she'll be back in no time. Remember what you named her, and that there high maintenance haha.
Mines still hurt from Texas, suspensions back, interiors back together, but still got electrical gremlins. Josh (my local LS guru) thinks i lost my MAF, i think that may be the case (i hope) as when i drove to Texas in the GG tour, i/we drove thru that super knarley storm and i believe i got water up in the MAF.....dunno....but sucs not driving it....
Mike
Old 01-29-2015, 08:19 PM
carbuff's Avatar
I'd love to step up to some All Pro, TFS/TEA, or other similar aftermarket castings. The consensus seems mixed as to what the gains from those are over a good CNC port on the L92's though, so I'm trying to decide the best path...
On the clutch, it can be done either way. In talking to Monster, the LT1 twin has a lower moment of inertia than a normal single disc pressure plate. Given that, the clutch will have a feel (in terms of momentum to launch the car) that falls between a steel and aluminum single-disc setup. So the lightweight twin would feel really light in that sense. Given that TOW is a pretty heavy car with me in her, I don't think the lightweight setup is the way to go...
Sorry to hear that yours is still having trouble! Electrical gremlins are the worst, so I'm glad I haven't really had any of those with TOW. Hopefully you can get everything sorted before the season starts out there for you west coast guys!
