Old 08-04-2019, 06:03 PM
MtotheIKEo MtotheIKEo is offline
Nice upgrade! Did you get lucky with the rotor and caliper offset matching the original offset? Or was there some spacers/milling to make it work?
Old 08-04-2019, 09:25 PM
jeff71 jeff71 is offline
Stock spindle? I'm surprised those Detroit Steel wheels required so little balance weight.
Old 08-05-2019, 07:54 AM
Stielow's Avatar
Stielow Stielow is offline
No I had to use CCP spindles that have a nice boss to build a adaptor off of.
Stielow Engineering
Old 08-05-2019, 07:56 AM
Stielow's Avatar
No a CCP spindle with a drop built in
Stielow Engineering
Old 08-06-2019, 08:18 AM
Ketzer's Avatar
Ketzer Ketzer is offline
I have read mixed reviews on the CPP stuff in general, ie quality issues. Glad to hear a real world use ! It's really tough trying to sort through reviews and figure out whos giving honest opinions.
Jeff-
Old 08-06-2019, 11:29 AM
ScotI ScotI is offline
Jeff-
Honestly.... They (the peoples opinions of CPP) probably all are. CPP is hit & miss. Some stuff is good as is. Some stuff not so much. The follow-up when you (the little guy/John Q. Public) do have an issue leaves you wondering how they remain in business.
Old 08-12-2019, 06:17 AM
Stielow's Avatar
I added 2018 Tahoe brake booster and master. I cut the brake booster brackets off the 1978 Blazer booster. The amazing thing is the rivet pattern matched the 2018 Tahoe booster. I changed the angle and it bolted up. I had to rework the brake booster rods but over all fairly straight forward.
Mark
Stielow Engineering
Old 08-12-2019, 07:07 AM
Mark
Curious.... Was this to simply keep the paired components together or is there some specific benefit to using the 2018 Tahoe booster vs. a 78 version?
Old 08-12-2019, 07:39 AM
Stielow's Avatar
Brake pedal feel. By putting the booster and master together and coping the pedal ratio of the Tahoe the brake pedal feel should be the same as the Tahoe. The only wild card is how keeping the rear drum brakes will effect things. If it is not good I’ll add the dicks to the back.
The 1978 booster had very poor brake pedal feel.
I also wanted the look of the modern booster and master.
To further update the truck I also added the Detroit Speed wiper motor and windshield squirters.
Hope to drive it as soon as I put the seats back in it. They are out getting redone with Chevy Highland Plaid material.
Stielow Engineering
Old 08-12-2019, 09:38 AM
bdahlg68's Avatar
bdahlg68 bdahlg68 is offline
Lmao you are going to do what?!?!?!
Damn autocorrect!
Brian
1968 Pontiac Firebird
1989 Ford Mustang
The Following 2 Users Say Thank You to bdahlg68 For This Useful Post:
camcojb (08-12-2019), gofastwclass (08-12-2019)
