Old 12-02-2020, 01:43 AM
Rodknock's Avatar
Rodknock Rodknock is offline
Default Rear Suspension install
Started installing some of the rear suspension components. I was going to polish the Heidts aluminum center section, but it was recommended to just do "chrome" powder coating. Sadly, that didn't turn out so well, but I'll live with it. Not really going to show under the car anyway. The powder coater felt really bad about it. He said it might happen (gassing). He cooked it in the oven for 5 hours, hoping to get the impurities out of it, but it still pitted. Just cheap dirty casting from the mfg. Nothing he could do. Only charged me $100, instead of the original $200 quote. I can't fault him, he tried. Even put several hours of prep into it before hand, to smooth it out.
Before
After
Other stuff going in
$500 doesn't buy much in the quality paint scene these days. The color I chose is up to $880 a gallon. I bought it a year ago for $600 a gallon. This is 2 quarts of jet black, 1 quart of black primer, and 1 gallon of clear, and the catalysts to go with them
John Rodko
69 Camaro RS/SS
Rolling shell, minimal rust.
Heidts Pro G IRS/ Heidts Pro G Front
DSE mini tubs
FUTURE PLANS:
T-56
Twin Turbo 6.0L
https://www.facebook.com/Angry-Johnn...?ref=bookmarks
The Following User Says Thank You to Rodknock For This Useful Post:
syborg tt (12-08-2024)
  #92
Old 12-02-2020, 02:51 AM
Spiffav8's Avatar
Spiffav8 Spiffav8 is offline
Lateral-g Moderator
Before
After
It works.
Curtis
The Following User Says Thank You to Spiffav8 For This Useful Post:
  #93
Old 12-02-2020, 08:21 AM
Rodknock's Avatar
It works.
Yup!! If I was building a show car, it would be a different story, but for a driver, it's good enough. Mainly wanted protection from the elements.
John Rodko
69 Camaro RS/SS
DSE mini tubs
FUTURE PLANS:
T-56
Twin Turbo 6.0L
The Following 2 Users Say Thank You to Rodknock For This Useful Post:
Cheveezy (12-02-2020), syborg tt (12-08-2024)
  #94
Old 12-02-2020, 11:26 AM
Spiffav8's Avatar
Lateral-g Moderator
Powder coating holds up really well. I'm glad I used it on my AME frame, rear suspension an diff. Also super easy to clean and keep looking nice. I think it's the smart move.
Curtis
waynieZ (12-02-2020)
  #95
Old 12-02-2020, 11:51 AM
I agree 100%
Old 12-03-2020, 05:04 PM
streetbird's Avatar
streetbird streetbird is offline
looking good, you work really fast
The French Frog
The Following User Says Thank You to streetbird For This Useful Post:
Rodknock (12-04-2020)
  #97
Old 12-04-2020, 01:38 AM
Rodknock's Avatar
8 years into a 2 year project, doesn't seem too fast to me
John Rodko
69 Camaro RS/SS
DSE mini tubs
FUTURE PLANS:
T-56
Twin Turbo 6.0L
Old 12-04-2020, 02:28 AM
Rodknock's Avatar
Got just a little bit more done before I got called to work. Was expecting to do more, but a plumbing leak at home, and getting called to work 11 hours earlier than expected, sorta changed things.
Got the third member installed into the housing, and got it all bolted up. Started installing the stub shafts, but that's as far as I got. I realized, after moving 3 different times, since I bought all this stuff, I am missing some hardware.
Don't have a brake caliper mounting bolts. Not sure what happened with those, so I'll have to find some.
Tried putting that heavy ass iron third member in with the housing in place...that's a negative ghost rider
This'll work
There it is
Just swing it up into place
John Rodko
69 Camaro RS/SS
DSE mini tubs
FUTURE PLANS:
T-56
Twin Turbo 6.0L
The Following 4 Users Say Thank You to Rodknock For This Useful Post:
EVIL SS (12-08-2020), Goosesdad (12-09-2020), Roscoe03 (07-21-2023), syborg tt (12-08-2024)
  #99
Old 12-09-2020, 09:17 AM
Rodknock's Avatar
Default Wheel Studs
For those contemplating a Heidt's setup, some of their stuff is kinda quirky. For instance, the front aluminum hubs are Willwood, and take a 1/2" wheel stud, but the rear hubs, are apparently Corvette hubs and have a 12mm wheel stud. Had to spend $100 for 10 new wheel studs from ARP. These are specific for converting C5 hubs to SAE 1/2" studs. Just drill out the hole with a 1/2" drill, and good to go.
Don't make fun of my spark plug socket on the press. As soon as the stud bottomed, I stopped. It was the perfect fit for what I needed to do.
Get out the BFH
I made sure the table was level with the drill head. Don't want it to be angled
Don't laugh, it worked
John Rodko
69 Camaro RS/SS
DSE mini tubs
FUTURE PLANS:
T-56
Twin Turbo 6.0L
syborg tt (12-08-2024), waynieZ (12-09-2020)
  #100
Old 12-09-2020, 09:25 AM
Rodknock's Avatar
Default Rear Suspension going in
Assembled more of the rear suspension stuff. Waiting on some Grade 8 fasteners to come in. Heidt's supplies Grade 5, which I'm sure is sufficient, but I like the pretty gold color of Grade 8
Almost time for wheel measuring!!345's babay!!
John Rodko
69 Camaro RS/SS
DSE mini tubs
FUTURE PLANS:
T-56
Twin Turbo 6.0L
