Old 09-25-2010, 12:04 PM
Default 32 Ford "tweaks" and a few mods
I hesitate to post this up since it's CLEARLY not a PT build or style car... But I figured it's a car - so maybe some are interested. So here it is.
Some of you already know that I bought a 32 Ford a week or so ago.... No, I wasn't in the market for one. I saw this car when I was in Sun Valley for the weekend and bought it...
So after living with it for a few days -- it needs to be modified a bit....
It is a 383 stroker - carbed - T56 6 speed - 8" Ford rear - Kugel Komponents IRS front end with their cast stainless arms... It's Ferrari Rosso Red. I like the car - but it just isn't quite right in a couple areas so I'll attempt to bring those few missteps in line.
Here's a couple pics of how it is now:
And here is the first napkin sketch:
It's at SAR (Steve's Auto Restoration) now and they'll start work ASAP. The plan is to do a Kugel Winters Quick Change with the cast stainless arms to match the front - change the steering wheel to a four spoke - change the wheels to the Schott Velocitys with knock off caps - ditch the 6 speed for a TKO 600 FIVE speed (with 3:90 gears) - loose the hood sides - Lake style exhaust - 8 stack EFI - change the headlight mounts...
Old 09-25-2010, 12:09 PM
This is the Kugel Winters Champ Quick Change:
Old 09-25-2010, 12:13 PM
Here's the wheel - so far - that we're thinking about using:
Old 09-25-2010, 12:21 PM
wiedemab's Avatar
wiedemab wiedemab is offline
Default Very Nice
I can't wait to see what you do with it. It looks like one heck of a nice starting point.
Brandon Wiedeman
'72 Suburban
'67 Chevy II -
Old 09-26-2010, 04:53 AM
fleet's Avatar
fleet fleet is online now
Greg, I really believe the car deserves a set of wheels that you personally design.
Impress us enough so that someday we may want to order a set of Weld wheels.
Old 09-26-2010, 07:15 AM
Skippers
That's been done before.... unfortunately for that particular Greg Weld... he was bankrupt and then passed away... fortunately I'm neither of those!
If I designed a wheel for the car - I'd have to spend the night at a Holiday Inn Express -- and then maybe I could come up with a chrome reverse wheel with a baby moon and wide whites... Oh wait! Then it would look like Brizios 55!
EEEEEEEEEHHHHHHHHHAAAAAAAAAAAA
Old 09-26-2010, 07:23 AM
fleet's Avatar
Insulting 2 hot rod icons in one post.. you did impress me.
Old 11-30-2010, 03:26 AM
tyoneal's Avatar
tyoneal tyoneal is offline
That is like a piece of ART!
How much power is it designed to handle?
How much unsprung weight does it save by moving the Brakes inboard?
What size are the brakes?
I love 32's and you have a beauty.
Ty
Project, "EnGULFed"
1964 Gulf Liveried, Corvette, "Grand Sport"
Ty O'Neal
"She Devil" aka. Betty
1969/70 Camaro SS
427 LS3, 600
Keisler Road and Track T-56
Full size 3 link and custom roll cage
315mm tires on rear, should fit the same on front. Worked to design a more effective shape.
"Chester's '65"
1965 Buick Riviera
Aiming for true PT Status with
the best available from the 70's and 80's
Old 11-30-2010, 08:55 AM
Ty
Thanks Ty! It is the perfect rear end for a build like I'm doing... where you can see the entire rear end from the rear of the car. It would be a complete waste in a car that would hide it.
I would imagine that you're saving 10 to 15 lbs per side of unsprung weight. The calipers and rotors are inboard but you have the extra suspension parts and control arm pivot points so it's not a pure negative moving the brakes in.
Here's KUGELS answer to your "how much HP" question:
It's all a function of power to weight to traction. You could have a 1,000 HP on an average street rod and the tires would break loose before anything else would break conversely. A heavier car with great traction and 400 HP will be much harder on the same rear end. Our ends use the proven 9" Ford gears. Heavy duty Corvette u-joints and castors weld steel half shafts. We just don't have any breakage problems. For extra heavy duty high HP we have custom 4-bar auto hub uprights.
Here's a view of the front of this bad boy.... BTW the price of these is not for the faint of heart... You can buy a LOT of other parts for what these bring. Mine was just short of 15 grand - not installed.....
Old 11-30-2010, 09:13 AM
96z28ss's Avatar
96z28ss 96z28ss is offline
1969 Camaro LS2/T56 D1SC
www.automotivedesigneng.com
