Old 07-01-2013, 10:03 AM
Payton King's Avatar
Default I was too lazy to go back and see
what brake calipers ans sizes you were running, but if you are using willwood in the C5/C6 sizing and a 6:1 pedal ratio, you can drop the rear master to 3/4 and adjust the bias more towards the front. Will give you a little longer pedal.
What pads are you running?
I would opt for the larger 550 lbs in the front and a 300 or 325 in the rear. Guess I should ask what rate you front bar is and if you are running a rear bar.
Old 07-01-2013, 10:21 AM
Jr's Avatar
Jr Jr is offline
Matt,
Who spec those master cylinders for you? Wildwood?
Old 07-01-2013, 11:05 AM
Matt@BOS's Avatar
Matt@BOS Matt@BOS is offline
Payton, I belive the piston sizes are 4.04 front, 1.98 rear. I don't think it would be that bad, but the Tilton pedals have a 5.29:1 ratio. If I drop to 3/4 rear I will probably need to add a proportioning valve since I doubt the balance bar will have enough adjustment. It might if I get the rod lengths close to right. My brain is hurting trying to visualize if that would affect bias too.
DJW, Wilwood spc'd the masters and did tell me if I wasn't happy to drop to a 3/4 (just now remembered that part of the conversation.
Old 07-02-2013, 06:49 AM
Default With that small of a ratio
I would run a .70 in the front and 3/4 in the rear. It will keep you bias correct, increase your pressure with the same leg input.
Those masters are a touch on the large size for the pedal ratio. I am guessing it takes a fair amount of leg effort on your part to get the car to stop.
What pads are you running? That will make the single biggest difference in your braking, feel and modulation than anything else you will do.
Old 07-02-2013, 08:27 AM
enzo enzo is offline
Default Matt,
You're crazy bro...
--Enzo
1967 Chevelle SS
http://namtramedia.com/enzo/67chevelle/
Old 07-02-2013, 10:36 AM
Flash68's Avatar
Flash68 Flash68 is offline
Originally Posted by enzo View Post
You're crazy bro...
2004 NASA AIX Mustang LS2 #14
1964 Lincoln Continental
2014 4 tap Keezer
Old 07-02-2013, 12:24 PM
Matt@BOS's Avatar
You're crazy bro...
That's what I used to think too. But, if you believe in the old catch 22 them I'm not crazy... just stupid.
Old 07-11-2013, 03:37 PM
morris69 morris69 is offline
Default intake
where did u get the first intake and valve covers from. secondly do u have any pictures of the interior? specifically the gauges?
Old 07-11-2013, 08:09 PM
Matt@BOS's Avatar
I got the intake manifold from Jeff Davis of Precision Metal Craft. I don't remember where the valve covers came from. I think I prefer them to the ones I have now, although the original ones I had didn't come with any venting.
Old 07-11-2013, 09:40 PM
fleet's Avatar
fleet fleet is offline
Matt,
This gettin' ready for Optima ain't for posers, huh?
Now, how bout some hi-res pics of Dead Pool?
