Old 01-06-2008, 06:07 PM
67turbostang's Avatar
67turbostang 67turbostang is offline
Default 67 Turbo Fastback Mustang
Well my project is moving right along. I fabricated and tig welded the 8 point cage. Ryan kertz got the new floors all spot welded in place. A lot of the suspension components were also welded, such as the rear upper coil-over mount, subframe connectors, watts link assembly, and torque arm kit. Ben Hermance is in the process of having some renderings done for me I cant wait.. I'm still somewhat new to this forum, so I'll give you a little info on my project.
1967 Fastback Mustang
dart 351 windsor block stroked to 427ci
forged internals
converted to fuel injection with twin 61mm turbos
griggs racing gr-350 coil-over suspension system
wilwood 14" front rotors 13" rear rotors
dpe 18" wheels
Old 01-06-2008, 06:20 PM
crc crc is offline
Lookin good! Keep the photos coming.
Old 01-06-2008, 09:30 PM
GHOSTDANCER GHOSTDANCER is offline
Looking good
Old 01-09-2008, 09:38 PM
EBMC's Avatar
EBMC EBMC is offline
Looking good! should be an awesome car when done. keep us updated!
Old 01-28-2008, 07:45 PM
i ordered my brakes today
front: 14" gt 2 piece rotors with 6 piston calipers
rear: 13" gt 2 piece rotors with 4 piston caliper with internal parking brake
i ordered the brakes with polished calipers, but i will have them anodized in blue.
i will post more progress pics as soon as i can figure out how to post larger pics.
Old 01-29-2008, 04:01 PM
Default progress pics
Roll cage that i fabricated and tig welded.
new floors
Old 05-12-2008, 07:00 PM
syborg tt's Avatar
nice project - really looking forward to watching the build.
marty-mj
Old 05-12-2008, 08:53 PM
Thanks.. I have enjoyed watching your build. very cool truck
Old 05-16-2008, 12:25 PM
preston preston is offline
Your subframe connector wher eit connects to the front rail - did you add any reinforcement at that attachment point ?
The little "stub" that comes off the main rail, ie where you have attached your subframe connector , is a very thin weak piece. I would add an extension or some kind of gusseting system to attach to the real frame horn. If you design it cleverly, you can reinforce the curved/bend area of your connector to make up for the weakness of a bent tube as well. Should only cost you about 4 lbs per side, 8 lbs total.
on edit: I took a closer look , it does appear you may have done some reinforcement there already. That "stub" is almost tinfoil thin compared tothe frame horn normally.
