Old 05-04-2010, 11:33 AM
68firebird's Avatar
68firebird 68firebird is offline
Default 68 firebird build
I'm working on a 1968 firebird. this is my first every build, so I'm learning as I go along. She's been sitting on jackstands in the garage since 2005, the kids are older now so now its time start this project back up. Long story short, I just don't have the space to pull the front clip off, the motor out, and the subframe out, I have a really small garage, but hey it beats working in the rain. oh, and I'm working on a pretty tight budget. progress so far: ( I apologize if the pics are kinda crappy, I use an iphone camera)
the wife was starting to use it as a shelf, didn't like that too much,
took the control arms off
took them to work, blasted them, primed and painted them with eastwood chassis paint, installed poly bushings, new ball joints, and new upper shafts.
Did the Guldstrand mod to both sides
covered up the front end and cleaned the subframe with flap disks, wire brushes, anything that would help me do the job.
painted the top of the wheelhouses since I had the front end masked up
once the frame was as clean as I could get it, I hit it with a couple coats of eastwood chassis primer then a couple coats of eastwood chassis paint.
Now its time for reassembly, just put the control arms on last night on both sides
so that's where I'm at right now. I've got hotchkis/bilstein shocks, hotchkis 2 inch lowering springs, global west subframe connectors and solid body mounts, and hotchkis sway bar yet to be installed. I'll be ordering some disk brakes over the next week or two to tie this front end up. More to come....
Rene P.
my 68 firebird low budget build----> https://lateral-g.net/forums/showthread.php4?t=26675
Old 05-04-2010, 12:23 PM
Nice progress. It looks good.
Old 05-04-2010, 05:50 PM
68firebird's Avatar
Hotchkis sway bar finally arrived today, I installed it (after I went to my local gm restoration shop to get the sway bar bushing bolts which I had tossed, thought this came with new bolts), then I just mocked it up on the endlinks for pics. this thing is huge, way bigger than the stock piece.
Rene P.
Old 05-04-2010, 11:23 PM
Tuske427's Avatar
Tuske427 Tuske427 is offline
Looking great! It's always good to see a Firebird being built up.
One tip for the next time you paint an engine bay or other irregular surface- use aluminum foil for masking off the areas you want covered. it's cheap (buy the generic) and conforms to many shapes. It can save some time versus wrapping up the paper and reduction in tape. I hope this helps!
Long Live the Muscle Car
https://lateral-g.net/forums/showthread.php4?t=26338
Instagram: @tuske427
Old 05-05-2010, 07:25 AM
68firebird's Avatar
That's actually a great tip, I'll use that idea in the future, thanks
Rene P.
Old 05-05-2010, 09:20 AM
67rstbkt 67rstbkt is offline
Nice progress and welcome to lat-g. I was following your build on p-t as well. Did you have any issues with drilling the holes for the g-mod? I just did it on my 'bird last week and was wondering about the curved section on the rear hole. It gave me a little trouble.....
Rusty Bird Build Thread:
https://lateral-g.net/forums/showthread.php4?t=18566
