Old 05-01-2006, 11:56 AM
Steve1968LS2's Avatar
Originally Posted by XcYZ
I really like that, I think that's what I need to do after I get the DSE subframe connectors installed. Do you think it added any appreciable weight?
Couldn't be much.. I will find how many tubes we went through and how much each tube's volume weighs.. It's not super thick and heavy like Line-X. I will also get the exact name of the stuff.
Nutsy Nutsy is offline
Originally Posted by Steve1968LS2
Spray on using a special spray gun.. thinner than Line-x.. like lizard skin..
What product is it?
Old 05-01-2006, 02:39 PM
B Schein's Avatar
B Schein B Schein is offline
It looks like Wurth, a water based under coating that Mercedes uses. Are you going to install the subframe conectors on Monday when you put the frame in .
Brian
Old 05-01-2006, 03:02 PM
Not sure.. might be another week before the subframes go in.. I am still wrapping my mind around how they mount.. lol.. Once I get the subframe in it will be easier to see where they need to weld.
The subframe is damn nice.. I can't wait to get it in.
I will get you guys the brand of the undercoat asap..
Old 05-01-2006, 03:33 PM
B Schein's Avatar
I can send you some pictures of the bottom side of our convertible if you want. let me know and will take some pictures tomorrow.
Brian
Old 05-01-2006, 03:35 PM
That would be great.. just not sure of how the back attaches.
you have my email.. right? if not Ed has it. Thanks!
Old 05-01-2006, 06:45 PM
trapin's Avatar
trapin trapin is offline
My Duplicolor Bedliner Coating arrived today. It comes with a special gun to spray it on that hooks up to an air compressor. Seems pretty straight forward. Sounds a lot like what you've got on Penny.
Tony Rapin
The Pigeon Forge Project
A 1968 Pro-Touring LS1 Camaro.........and why not?
Old 05-01-2006, 06:57 PM
Most likely the same concept.. but it was a name I hadn't heard before. I will drop by the shop tomorrow and get the actual name
Old 05-18-2006, 05:16 PM
I finally got that info on the stuff we used for the underside..
FUSER – Wheelhouse textured coating and sealer .. part number 805
7 tubes weigh about 5lbs.. Once the solvents evap away I bet it only added three-four pounds to the car. The finish is slighly rubbery, good for rocks.
Hope this helps..
Old 05-18-2006, 05:38 PM
4mm 4mm is offline
Steve, have you already coated your pulleys? I recall you metioning you were looking into powdercoating or anodizing.
