Old 04-29-2012, 02:16 PM
cencalc6 cencalc6 is offline
Always looking forward to your progress....Excellent Photography!
Old 04-29-2012, 02:26 PM
FETorino's Avatar
FETorino FETorino is offline
Talking
I can never seem to get my head around if I am more impressed with your fabrication skills; your sense of design for the overall project; the cleanliness of your garage; your photography skills?
Whatever it is you thread is always worth a look and your build is sweet
Rob in SoCal
Old 04-29-2012, 02:37 PM
Openers's Avatar
Openers Openers is offline
I'm ah...lost for words. Humble thanks! You made my day...or night which it is here in Sweden
Camaro T/A on Facebook
Old 04-29-2012, 02:58 PM
Track Junky's Avatar
Originally Posted by Openers View Post
Thanks guys!
2" wider front wheels are already ordered. When the build is in its final stage a new set of tires will be mounted - wider up front and slightly less wide in the back...
Perfect!! I think that will give you alot better balance.
Gaetano Cosentino
Old 05-01-2012, 10:45 AM
Openers's Avatar
Pedal assembly with adjustable brake balancer.
Battery tray installed.
Old 05-01-2012, 12:21 PM
Knaller's Avatar
Knaller Knaller is offline
If you don't mind asking, what tire size did you use for mockup?
Old 05-02-2012, 12:13 AM
Openers's Avatar
28/12.5-15 in the back and approx 25/9-15 up front. Will go for 26/11-15 and 25/9.5-15 when finished.
Old 05-02-2012, 12:36 AM
Flash68's Avatar
Flash68 Flash68 is offline
So freakin bad ass... where'd ya get that pedal assmby from?
You nailed it.
2004 NASA AIX Mustang LS2 #14
1964 Lincoln Continental
2014 4 tap Keezer
Old 05-02-2012, 11:46 AM
Knaller's Avatar
That is exact why i ask. I am in the same boat. 28 in the back fill the wheelhouse pretty good, but 26 look a little small especially in a Nova with the more square shape. I limited to 17" rims and don't want to go with truck tires when going up to 28"... The wheels in your Camaro look perfect. Outstanding build !
Old 05-03-2012, 04:13 AM
Openers's Avatar
You nailed it.
Thanks! =)
Pedal assembly is from obp.
