Originally Posted by MX145
I've also been working on the hydraulic clutch setup. As I mentioned a few days ago I can't find specs anywhere on the internet for the 98-2002 GM master cylinder so the bottom bolt pattern is a guess based on another rough template I found that was missing a lot of dimensions. Because of this I started from scratch with my own measurements for the entire thing. I also wanted to closely follow the firewall contours especially above the brake master cylinder and retain the factory speedometer cable location. I'll update the bottom bolt pattern when I pick up the clutch master cylinder. I was able to measure the rest of it out based on the car and my Wilwood brake master cylinder and it seems to fit well.
Putting in some leg work
I just bought mine from ebay and called it a day.
But again last time I did any CAD work my computer screen was black and green and had to type 20 commands to make 1 dot.
Great work
