Old 07-06-2015, 03:39 PM
atomicjoe23 atomicjoe23 is offline
So is the bolt-on version for the New/Big Ford ends available now???
If so. . .pricing on a complete bolt-on kit???
Also, you mentioned the weld-on kit is butt welded. . .what diameter axle tube are these set-up for?
'67 Pontiac Firebird 400 RA coupe
http://www.pro-touring.com/forum/showthread.php?t=26557
'97 Chevy Camaro 3.8/M5 coupe
'02 Yamaha R1
'01 Aprilia RS50
'00 Yamaha R6
Old 07-07-2015, 06:41 PM
MillerBuilt's Avatar
MillerBuilt MillerBuilt is offline
Originally Posted by RoadRace Elco View Post
The factory flanges 4 but top are narrow bottom wider
Sorry but you would only be a candidate for the weld-on kit. Cut your current ends off, and weld on the new C6 ends.
Yes, I do have a few sets of bolt-on kits available. A "complete bolt-on kit" is $1650 plus PayPal/Shipping.
Yes, the weld-on kit is butt welded, and will accommodate tube outside diameters 2-5/8" to 3-1/2". Pretty much anything...
PM me your phone# and Ill give you a call.
Thanks, Jay
Old 07-07-2015, 08:37 PM
carbuff's Avatar
carbuff carbuff is offline
Jay,
I may be in the market for something just like this... I would be interested in the weld-on kit. You mentioned earlier in the thread that Strange was onboard to offer their housings with your flanges welded on. I presume that's not an option available on their site anywhere. Would the purchase take place directly through them, or the kit through you and then shipped to them? Trying to determine the logistics.
Thanx...
Old 07-08-2015, 06:12 AM
Originally Posted by carbuff View Post
Jay,
Thanx...
Yes, you would still purchase the kit from me and I would ship the kit to STRANGE along with fixture blocks for correct alignment. I had spoke with STRANGE in detail about the kit and they stated they would be able to weld on the C6 steel flanges since they install exactly the same way as any other flange end.
The only variable would be what specific suspension/brackets you're requiring. They mentioned that they do not install ALL types so it would be at their discretion once that info was supplied. So if you call them about housing info, also supply them with your suspension bracket needs to determine if you are a candidate. I have been quoted by STRANGE $150 to weld on the C6 flanges....
When you call STRANGE remember you are speaking with any one of the many sales staff and most likely will be clueless of my set-up, so don't be surprised if you are getting deer in the headlight look through the phone. Just get the housing/bracket quote, add the $150 for flange install and when ready I will assist with getting the correct order placed. I am currently helping another gentleman out with his axle order since he is getting that same deer in the headlight look
Let me know if you have any other questions and I will do my best to answer.
Jay
Old 07-08-2015, 07:11 AM
Thanks, Jay
Thanks Jay. . .I'll get a hold of you soon. I need to source my rear end. . .this kinda changes my build plan a little, but I hadn't laid any money out on anything for the rear end yet, and I hadn't started designing my rear suspension yet either so I'm pretty golden it sounds like.
Thanks!!!
'02 Yamaha R1
'01 Aprilia RS50
'00 Yamaha R6
Old 07-10-2015, 12:01 PM
Jay, would you happen to have any photos of the bolt-on kits?
What does the complete kit include?
Also, how much width (if any) does the kit add to your WMS-to-WMS width? I'm guessing it doesn't and bolts to the back of the flanges, but since I haven't seen photos I'm not 100% positive and just want to make sure before I order a rear end.
Thanks!!!
'02 Yamaha R1
'01 Aprilia RS50
'00 Yamaha R6
Old 07-10-2015, 11:40 PM
Vince@Meanstreets's Avatar
Thanks!!!
.250in per side according to
https://lateral-g.net/forums/showthread.php4?t=49657
MEANSTREETS PERFORMANCE
Dealer for
NEVER FORGET -11
Old 07-11-2015, 01:25 PM
Thanks!!!
Hi Joe,
You probably have utilized the link that Vince supplied so please visit that link to see pics (just posted a few new ones as well). The complete kit includes everything you will need except; Rotors, Calipers, e-brake cables & Axles.
Everything else that you would need is included; C6 Flanges, C7 SKF Hub Units, complete C6 E-brake setup, all hardware, axle seals.
Let me know if there is anything else.
Thank you,
Jay
Vince, thank you for helping out as usual
Old 07-11-2015, 09:58 PM
Thanks Jay & Vince. . .I didn't realize there was a thread just for the bolt-on kit; I found this thread by following a link from another thread. . .
'02 Yamaha R1
'01 Aprilia RS50
'00 Yamaha R6
Old 08-16-2015, 07:05 PM
Another Complete C6/7 Weld-on Kit headed out to Northern CA. This customer will be utilizing the free fixture pieces that I loan out to install his own flange ends correctly.
Will now be running another batch. Thanks to you that have purchased, AND to you that are soon to purchase!
