Old 09-03-2015, 05:29 PM
Vega$69's Avatar
Vega$69 Vega$69 is offline
Originally Posted by Swain View Post
Damn fix one this then another thing goes wrong.
My fuel pump wire lost power. Fuse is good relay is good. what the..............
PSI Harness. Fuel Pump relay gets 12V from the ECM when Ign is turned on.
So are you saying you don't have 12 on the wire that goes from the relay to the pump?
Old 09-04-2015, 02:28 PM
Swain's Avatar
Swain Swain is offline
No Power so its mailed back out to Gary @ PSI
He said he would get it fixed and set back to me. Ill get there soon
Jason Swain
Build Link 68 Camaro
https://lateral-g.net/forums/showthread.php4?t=16865
Old 09-04-2015, 04:00 PM
rickpaw rickpaw is offline
Before you send it back to PSI, just be aware that the ECU shuts off the power to the fuel pump after 5 s (I think) if the engine is not running. Not sure if you know that or not.
Tu Ho
Old 09-04-2015, 06:02 PM
Swain's Avatar
It use to do that now it does t have any power coming from the ECU.
Jason Swain
Old 09-14-2015, 02:45 PM
Swain's Avatar
Back at it....
ECU Re Programmed everything seems like it should run. It wants to start but just wont fire.
My fuel pressure is only at 50 PSI could that be too low?
Jason Swain
Old 09-14-2015, 04:15 PM
Vega$69's Avatar
Back at it....
It should start and run just fine with 50 PSI
Old 09-22-2015, 05:27 AM
67Rally's Avatar
67Rally 67Rally is offline
Back at it....
Make sure you have 12v going to red ignition wire with "key on & cranking".
The wire I fed it with had power with key key on only, but nothing when cranking. It would turn over, but not fire up. It's a fairly common issue (sorry if you have already checked this).
Old 10-06-2015, 10:01 PM
Swain's Avatar
So my new Vaporworks tanks in. I hooked up a scanner to the car and its throwing a P0135 code. The scanner says Crank sensor but I changed it. Online forums says o2 sensor. Hmmmm
Jason Swain
Old 10-07-2015, 06:14 AM
Vega$69's Avatar
Does it start and run now?
Car will still run with the P0135 code. In fact it should start and run even if the O2 sensors are not installed.
Old 10-07-2015, 07:47 AM
Swain's Avatar
No start it wants to start it sounds like but nothing
Jason Swain
