Closed Thread
Old 07-14-2006, 02:00 PM
Originally Posted by tyoneal
Maybe the DSE sibframe with Tyler's spindles is the magic combination.
That will not be a possibility due to the design of the Corvette upright on the DSE sub. Our spindle cannot bolt to the upper control arm with the current config that is on the frame due to the inverted upper ball joint. Maybe DSE will make a provision for our AFX spindle? Can't hurt to hope...
Originally Posted by Stuart Adams
I would be very interested in the stress testing that was put into the AFX spindle also. GM puts alot of testing in their spindle and had problems with breakage in the past that caused projects to be shut down until fixed.
Stuart-
We did lots of engineering, FEA, and actual physical destructive testing on our spindles. I can say that without a doubt they are stronger than the C5/C6 spindle by quite a bit. The C6 spindle is a pressure casting from A356-T6 aluminum vs our forging in 6061-T6 aircraft grade aluminum. I'm going to save my typing fingers, and cut and paste a response toa Chevelles.com thread where people questioned our spindle:
Here is the link to the thread:
http://www.chevelles.com/forums/show...&highlight=ATs
Here is the response that Shane wrote:
Alright guys I'll try and layout our design process for these spindles based on your inquiries and concerns. First let me state that yes it is extremely expensive (especially for a two man team) to replicate all the tests that parts have to endure in the OE's, but we have tried to cover all the aspects of the test and design phases to our capabilities by contacting multiple engineers in GM, other suspension engineers, and different vendors involved in designing the C5 knuckle in order to achieve these goals.
In the initial stages we fabricated a test spindle much like the Stielow spindle but utilizing a C5 bearing cartridge and an adjustable steer arm. We acquired control arms from Global West, DSE, and Speetech and did camber curves, caster curves, plotted pivot points, in both the stock location and gulstrand location for both the AFX spindle and stock spindle. This was done to know our baselines and to be able to tell the customer how our spindle will work with any combination and how it will affect their application. We are currently in the process of working with SC&C to do the same for the A-body platform so we can accomodate those that have already done the B-Body spindle conversions and have the shorter UCAs and also to design an UCA that is specific and optimized for the AFX spindle.
All the components for the orginal fabricated spindle and current forged spindle were modeled in Solidworks and had simple wheel load FEA done on them by both myself and the forging company since we already knew the fabricated spindle has taken a ton of abuse on the Thrasher Camaro. I have taken specialty classes in both finite analysis using ANSYS and strain gauge testing. Next we got in contact with one of the original reps that worked for the manufacturing company that did the C5 pressure cast aluminum spindle. He was able to tell us the constaints and requirements that GM demanded for their design. The C5 spindle is actually a pressure cast A356-T6 alloy while ours is a must stronger forged 6061-T6. For those that want numbers The UTS is 228 MPa vs. 310 MPa, Tensile YS is 152 MPa vs. 276 MPa, and Elongation at break is 3% vs. 12% for the C5 vs. the AFX materials. Our selection of material was discussed in long detail and initial FEA was done based on our current model by both myself and the forging company taking in to account a safety factor of 5. Not only is our spindle more ductile but it is also a lot stronger and those that know how forging works know how the grain structure is worked so that it flows in the direction of the part for optimal strength. The AFX is also almost 1.5x thicker everywhere than a C5 spindle. Now let me say that the FEA was used just as a tool for the design process not as a corner stone. I will get into the true destructive testing later.
Other aspects that we looked into and talked with GM engineers on was one thing that was stated above about the new Z06 twisting the brake bracket which I can concur was true. They had to redesign the spindle to be beefier for the 6-piston calipers. We took this knowledge and also incorporated about a 50% thicker caliper bracket which is also reinforced into the lower ball joint with stratigically placed variable fillets. Another issue plaguing the C5 knuckle was the lower ball joint taper fatiquing after each torque cycle of the ball joint. We took care of this issue by introducing harder 7075-T6 inserts that are frozen in liquid nitrogen and placed into the extremely precision machined holes of the spindle, which upon reaching room temperature maintain an adequete interference fit. On top of the interferance fit we use heavy duty spiral locks with an additional tensile strength of 211,000 psi to prevent any initial backing out on top of the interferance fit and mostly to reduce the risk of tampering.
Now onto the manufacturing. Number one is quality control and precision. The forging company we chose is in the USA and has been in business for over 40 years doing stuff for both military and the OEs. Each and every raw forging is inspected and 1 out of 10 has a tensile sample ran with it to check the material properties and their consitancy. Also we recieve a certification sheet showing the critical dimensions for each part and their tolerances. The machine process involves a 7-axis CNC with an integrated CMM probe to maintain all the stringent tolerances that are called out. I personally have 2 years of experience working with quality control and operating a CMM so I have a really good grasp on what I am looking for and what is required. Some may argue that some of this is over kill, but all our products must be top notch regardless if this is just the aftermarket.
Now on to the testing. We are in the process of contructing a pretty elaborate test station that will simulate wheel loads on the spindle and record the loads and deflection in the spindle. We plan on taking it to the point of failure multiple times. We are also putting a few sets on some Camaros right now that will be running on some road racing events later this month and running very wide tires. They will be putting some serious loads on these spindles. The road testing will be an on going operation that we will be tracking even after we start selling the AFX spindles. We are also working with another GM engineer to meet any other validating tests that he thinks are necessary. With all this said you can see we are going all out to make sure that these are safe, sound, and proven. As an engineer myself I can understand some worries with such a critical part of your vehicle and thats why we are being so aggressive with them and I am personally going to run them on my 87 Grand National. We have worked with the experts on these and I can guarentee we have a product that is of high caliber. Please let me know if you have any other concerns or questions.
I also wanted to add that our pricing currently is $625 a pair with brand new C5 hubs and all the hardware. BTW dennis thanks for the nice comments and as for the spindle height the tall version is 8.5" tall and with 1" taller upper and lower ball joints that would get you your 10" tall spindle along with a 1 7/8" drop. Like I said we are working with the A/G body guru Marcus at SC&C since he has a test frame to optimize this for that platform.
EDIT- Upon further reading of this post, there is 1 item that is incorrect- We do not use a 7075 T6 lower ball joint insert, and it is not pressed in place. We use 4130 steel lower inserts that screw into the spindle to help distribute the load into the spindle. It is now even stronger than it was when we first designed it. Our spindle failed after it saw 12x's the load it was designed for. We cycle loaded the spindle to 10 tons, and took it back down to zero, and multiple dial indicators showed ZERO deformation upon release of the load. We took it back up to find the breaking point, and it was just over 24,000 lbs.
I still need to take out some classified info from our excel spreadsheet, and then make it a .jpg for you guys to view. I'll be working on that later tonight, as I'm tied up de-bugging our new shopping cart.
Tyler
  #102
Old 07-14-2006, 03:13 PM
wickedmotorhead's Avatar
wickedmotorhead wickedmotorhead is offline
Here's our hard numbers with use of all stock components and just our spindle and also with a Global West upper for which we are dealers for. Also included a bumpsteer chart. All this data is actual test data not from a suspension program. This is for a First Generation Camaro. We will be putting all this on our new website along with the other applications such as Chevelles and G-Bodies.
I agree with Mark on his points with suspension. Don't get to involved with comparing just hard numbers since there are a lot of other factors involved such as spring rates, ride heights, purpose of the car, etc.
Shane
Shane Wagner
1970 Chevelle "WSS"
1965 Chevelle "Proven1"
  #103
Old 07-14-2006, 08:03 PM
Leadfoot1's Avatar
Leadfoot1 Leadfoot1 is offline
I really like the "Turn" this discussion has taken from what sounded like the beginning of war at some point, this is getting seriously interesting...
Lead.
LEADFOOT1
New for summer '13. My latest find!!
48k miles, 100% original, 1969 Camaro coupe. Untouched, never apart and squeaky clean!!! 327/th350, A/C car. Gold on black w/vinyl top. Only add ons; Fast ratio box and SS396 wheels.
FINALLY!!! A car without rust repairs ever!!! None before, none coming!!! Cant come to modifying it tough....
...So, '67 Camaro project with my laying around stuff out of my black 'vert. 468 BB and YSI blower, braked th400, 12 bolt/spool, 35 splines etc. Complete Calvert suspension front and rear. 30x13.5 ET Streets, caged, lightened, slammed and running low 9's "Street car"
  #104
Old 07-14-2006, 09:13 PM
G-Body's Avatar
G-Body G-Body is offline
Should of work harder on getting the price right! your units will be outsold 10 fold, praise for a great product! now make one people will afford
  #105
Old 07-14-2006, 09:53 PM
Ummgawa's Avatar
Ummgawa Ummgawa is offline
This has been one of the best threads I have read in a while. Thanks Tyler and others for all the great information. Laying it out there info wise is cool.
I am glad this did not turn into a pissing match.
Jim
  #106
Old 07-14-2006, 10:18 PM
Vince@Meanstreets's Avatar
Default performance
good stuff guys. The frame looks interesting and can't wait to use one.
Gbody, If you sit and think about it, $67 isn't a whole lot of money considering your average hobbyist will spend that to band aid a frame and/or suspension to perform maybe half as good as we anticipate the DSE unit to do.
Now having used several Alston frames in the past I can tell you that the amount of money spent there is just for stronger welds, prettier frame than stock and no other performance gains. Maybe a 5 in cool factor but that drops to 2 when you get passed by a stock equipt frame with a g mod.
Im sure most of us can afford it if we cut fundage on other portions of our builds. ie: cheaper headers, carb, ignition system, 9k paint to 5k paint, and loose the 2k in stereo equipment.
  #107
Old 07-15-2006, 04:15 AM
Originally Posted by Steve1968LS2
DSE SUBFRAME SPECIFICATIONS
NOMINAL CAMBER
- 0.5°
NOMINAL CASTER
+ 4.5° (ADJUSTABLE TO 5.5°)
TOTAL SUSPENSION TRAVEL
4.0"
TOTAL BUMPSTEER, 30" TOE-SPAN
0.070" OVER 4" OF TRAVEL
TURNING ANGLE ( 18"x10" OR 17"x9" WHEELS )
30.0°
ACKERMAN ANGLE ( 18"x10" OR 17"x9" WHEELS )
2.5°
TURNING ANGLE ( 18"x9" WHEELS )
33.8°
ACKERMAN ANGLE ( 18"x9" WHEELS )
3.5°
Ok, time for the experts to sort that out
Steve you are so right about it!! Yes we all are eager to jugde the looks and price of different products but have no clue what these numbers and terms really means!! I highly appreciate the the Marks@lateral dynamics and Tylers input of clarify all details to us. Plese keep talking and opening all details for us Would be a big help before spending big money.
Could someone point out the major benefits betveen stock subframe modified with all DSE coil over kit and R&P vs. New DSE subframe ? Is the difference possible to "feel" on the road or track ?
63 Z06
  #108
Old 07-15-2006, 06:38 AM
Ummgawa's Avatar
The DSE pieces are excellent, However, Stielow is still using a modified factory frame on his latest build if I am not mistaken. Am I right or wrong here?
Jim
  #109
Old 07-15-2006, 06:40 AM
Sales@Dutchboys's Avatar
yes you are right......although the sub was not out when he was building it....Who nows maybe he will put one under it......
dutchboyshotrods.com
269-823-2967
  #110
Old 07-15-2006, 08:17 AM
Steve1968LS2's Avatar
The two biggest advantages over a stock sub I see right off the bat are:
1. The DSE sub is designed to accomodate a rack/pinion, so it's easier to get the geometry right.
2. Less labor then welding up the stock sub. Modifying for coil overs and reworking it for a rack.
It also looks like they really reworked the geometry, but I am not expert enough to give an opinion on it. The nice part about DSE is that you know the quality is top notch.
A car with good geometry is just nicer to drive on the road. Too much scrub radius or bump steer just makes it a PITA to drive. So yes, you would feel the difference in a good frame over a bad one.
Closed Thread
