Old 10-06-2023, 06:03 PM
Cramer4918's Avatar
Cramer4918 Cramer4918 is offline
Just one more update for now.
I purchased an AC hose crimper to try and get my system buttoned up.
Don’t mind the Firetruck and Ambulance in the background. I don’t have a vice much less a work table in my garage. Some things I have to do while on duty during my down time hours.
I learned from Marty to put the tape back from the fitting so I would not have to worry about digging it out after crimping. Thank you, sir!
Getting the hoses installed.
I just noticed my pet moth died as well. R.I.P little buddy.
Remember, I will be going back through everything to refine the finished product.
Plenty of clearance for the hinge when the hood is closed.
This is how I’m thinking the lines will be ran on the fenderwell.
-Matt-
'61 Biscayne ~ AKA BISKWIK
The Following 3 Users Say Thank You to Cramer4918 For This Useful Post:
fleet (10-11-2023), Goosesdad (10-06-2023), syborg tt (10-20-2023)
  #102
Old 10-08-2023, 07:42 PM
linenoise linenoise is offline
I ended up going with the smaller more flexible lines in the EZ clip setup.
This is so nice routing lines....Saw it on a youtube video right before I put mine on with the typical hoses.
https://www.lsxconcepts.com/products...erant-hose-kit
https://www.youtube.com/watch?v=536BqlO3AWI
The Following 2 Users Say Thank You to linenoise For This Useful Post:
camcojb (10-08-2023), Cramer4918 (10-10-2023)
  #103
Old 10-10-2023, 06:08 PM
Cramer4918's Avatar
I did manage to purchase the reduced barrier hoses that run into the cabin. They definitely made it easier to manipulate the hoses under the dash. The EZ Clip system is nice for sure.
-Matt-
Old 10-11-2023, 05:36 PM
Che70velle's Avatar
Great to see progress Matt. Keep at it sir.
Thanks Dad!!
The Following User Says Thank You to Che70velle For This Useful Post:
Cramer4918 (10-12-2023)
  #105
Old 10-12-2023, 02:09 PM
Cramer4918's Avatar
Thanks, Scott! I am trying.
I think one of the next big ventures is going to be the exhaust. As my insomnia was in full force last night, I pondered over how I was going to run it with the frame bracing. I came to the decision of cutting the frame bracing out completely, running the exhaust and then reinstalling the bracing with channels for the exhaust to run through.
It sounds good in theory. I'll have to see if it comes to fruition.
Hope all is well for you, brother. Get up with me sometime when you're not too busy.
-Matt-
The Following User Says Thank You to Cramer4918 For This Useful Post:
Che70velle (10-19-2023)
  #106
Old 10-16-2023, 11:50 AM
Cramer4918's Avatar
Default Introducing BISKWIK
Yup…. I was left alone and unsupervised again!
I went ahead and started removing the underbracing so the exhaust could be ran. I have a plan to plumb the exhaust and then add in the underbracing with channels for the exhaust. We shall see how it turns out. I may have to completely scrap the bracing, but I’m hoping not.
Left alone and with power tools. Here goes nothing!
A little unfortunate collateral damage.
So much room for activities!!! Seriously though, it will be nice to have the exhaust tucked where it should be or at least close to it.
Rough cleanup
Cleaned up enough to run the exhaust and go from there.
Just remember, I’m doing all this with the car on jack stands and me laying on the floor. 100% garage (floor) build!!
-Matt-
The Following 4 Users Say Thank You to Cramer4918 For This Useful Post:
camcojb (10-16-2023), Che70velle (10-19-2023), Goosesdad (10-20-2023), WSSix (10-16-2023)
  #107
Old 10-20-2023, 08:13 AM
syborg tt's Avatar
Hi Matt,
You're welcome and I have learned so much from this board that I feel the need to share what I learned and the mistakes I make.
Poor little guy I hope you find his family and give him a proper send off.
marty-mj
The Following User Says Thank You to syborg tt For This Useful Post:
Cramer4918 (10-24-2023)
  #108
Old 11-05-2023, 09:02 AM
Cramer4918's Avatar
Hi Matt,
I hear you, Marty. There is definitely a wealth of knowledge here. I plan on doing the same!
We certainly did. He is enjoying eternal flight around the light in the sky.
-Matt-
Old 11-05-2023, 09:05 AM
Cramer4918's Avatar
I am starting the fun part of mocking up the exhaust.
I purchased a Magnaflow 2.5” Stainless Builder’s Kit
Now the daunting task of fitting this under BISKWIK.
-Matt-
The Following 2 Users Say Thank You to Cramer4918 For This Useful Post:
camcojb (11-05-2023), Roscoe03 (11-14-2023)
  #110
Old 11-05-2023, 09:23 AM
Cramer4918's Avatar
Starting the process..
I used a section of the straight pipe to line up on the bottom of the frame to check my ground clearance.
Fitting the minor bend before the turn towards the back.
Making the turn back.
Plenty of clearance for the tire.
Who knew Painter’s tape would be so versatile?!?!
I used the boxes to assure there was plenty of clearance for the exhaust since they are right at the height of the bottom of the frame.
-Matt-
