Old 09-01-2023, 08:31 AM
ScotI ScotI is offline
You can run “Big” or oppose piston brakes with the OE Forgeline wheel. It just pushes the center out board and make the center cap look odd.
See attached photos. The outer rim half is not very deep and IMO the center cap pushed out like this is not my preference.
Yes sir.... I've discussed this in-depth w/my No.1 car buddy & agree w/you 1000%.
I do not care for the hub cap protruding beyond the wheel lip. Yes, it's still an OE appearing set-up but that cap hanging out beyond the rim lip is too much outside of 'the look' for me.
That's what had me questioning what set-ups are compatible.
Thanks for your input.
Old 09-02-2023, 04:13 AM
srode1 srode1 is offline
Looks like the extra metal for a convertible rear seat area ledge was added, assume that was for stiffening? I didn't notice this on your last build, maybe just didn't catch it.
Old 09-02-2023, 01:34 PM
Stielow's Avatar
Stielow Stielow is offline
The new floor pans came with it so we added it.
Stielow Engineering
Old 09-02-2023, 03:40 PM
Stielow's Avatar
When the previous owner had it the fire wall got messed up.
Because it is an original BBC car we are going to keep the stock heat box look in the engine bay
Stielow Engineering
Old 09-15-2023, 03:39 PM
Stielow's Avatar
Modified the heater box. We will add the pass thoughs later
Stielow Engineering
Old 09-15-2023, 03:48 PM
Stielow's Avatar
Working on the transmission tunnel to get clearance for the D&D Tremec 6 speed. It also helps the driveline angles.
Stielow Engineering
Old 09-17-2023, 08:32 PM
syborg tt's Avatar
syborg tt syborg tt is online now
Stunning work.
Next time we head to the Autorama I would love to see his shop.
marty-mj
Old 10-18-2023, 04:09 PM
jeff71 jeff71 is offline
Updates?
Old 10-18-2023, 04:27 PM
Stielow's Avatar
I got a second set of wheels for “street” use. To get the look I wanted I had to go to slider stock brakes.
Stielow Engineering
Old 10-18-2023, 04:28 PM
Stielow's Avatar
Engine mock up
Stielow Engineering
