Old 09-02-2018, 05:08 PM
Steve68 Steve68 is offline
Curtis, My next problem, I was trying to use my ATS plates, which puts the engine to far back in the sub, which plates did you use, I looked at AME didnt see any, thanks
Old 09-02-2018, 05:39 PM
dhutton dhutton is offline
AME sells plates for their subframe.
Don
Old 09-02-2018, 05:45 PM
jwcarguy jwcarguy is offline
Banned
Steve,
We used the plates from AME
And as Don mentioned, they are available from AME
They dont postion engine back as far as I would like, but still has plenty of clearance in front also
Jeff
Old 09-02-2018, 11:07 PM
Spiffav8's Avatar
Spiffav8 Spiffav8 is offline
Lateral-g Moderator
As Don and Jeff stated AME makes a set. I believe they have updated the design for a better fit since I received mine. A quick phone call and they will have you all set.
Curtis
Old 09-03-2018, 06:10 AM
Thank you all for replying, I looked at the website but didn't see much, but I'll make that call, again thanks
Old 09-03-2018, 06:17 AM
Download the catalog and you will find them.
Don
Old 09-03-2018, 03:43 PM
Spiffav8's Avatar
Lateral-g Moderator
Don
I looked it up. Page 66
Make sure you look at the directions online before you go and try to stab the engine!!
Curtis
Old 09-05-2018, 07:08 AM
Again thanks guys for doing the research,
What are theses directions you speak of Curtis?
I found them in the catalog, for some reason I never thought to look there,
Old 09-05-2018, 10:40 AM
Spiffav8's Avatar
Lateral-g Moderator
When I installed mine, I missed the Note which states... Due to manufacturing tolerances, this area may need to be trimmed in some applications. We had the engine about 1/4" from being right where it needed to be to bolt in and found the mounts where touching the frame. This caused a bit of a head scratching for a few till I revisited the instructions. It was a pain, but we removed, trimmed and reinstalled the mounts. Everything lined up perfectly and fit without issue.
http://artmorrison.com/instructions/...-MOUNT-KIT.PDF
Curtis
Old 09-05-2018, 05:28 PM
DBasher's Avatar
DBasher DBasher is offline
I just wanted to say thank you, Curtis. Not only for showing off the painfully slow build and helping others every opportunity you can, but also for not EVER changing your avatar.
Tonight I raise a glass to you, sir!
The Following 2 Users Say Thank You to DBasher For This Useful Post:
GregWeld (09-05-2018), waynieZ (09-05-2018)
