Old 01-19-2022, 12:58 PM
SSLance's Avatar
SSLance SSLance is offline
Suspicion confirmed...
Now just have to find time to schedule the uninstall\correct\reinstall procedure...
Lance
Old 01-19-2022, 01:04 PM
syborg tt's Avatar
Good news is you now know what it is. The Bad news is now you have to find the time to actually fix it.
marty-mj
Old 01-19-2022, 01:19 PM
ScotI ScotI is offline
Pardon my ignorance w/the t56's & the TO bearing pieces..... What is the red shrapnel I'm seeing?
Old 01-19-2022, 02:19 PM
SSLance's Avatar
It's powder coat from the back side of the pressure plate. When the bolt broke, the fork pressed up against the spinning pressure plate, peeling off the powdercoat and a few aluminum shavings.
Lance
Old 01-19-2022, 02:20 PM
SSLance's Avatar
That might just happen tomorrow, I've cleared my docket!!
I think the hardest part might end up being the retrieval of the two broken bolt pieces.
Might try to re-engineer the setup a bit while it's out also.
Lance
The Following 2 Users Say Thank You to SSLance For This Useful Post:
camcojb (01-19-2022), syborg tt (01-19-2022)
  #1156
Old 01-20-2022, 08:47 AM
syborg tt's Avatar
Might...Come on we have seen this build of course you are going to re-engineer it.
marty-mj
Old 01-20-2022, 01:52 PM
SSLance's Avatar
Well, this should be fun to get out...
Had a very liberal coat of loc-tite on it when it went in the last time about 7 years ago...
Lance
Old 01-20-2022, 03:05 PM
syborg tt's Avatar
Eak - that does not look like fun
marty-mj
Old 01-21-2022, 08:39 AM
Jimmy Sean's Avatar
Jimmy Sean Jimmy Sean is offline
Assuming you know this but sharing for all, a little heat helps with removal of items that have loc-tite on them.
1969 Firebird, L-76 LS2, T56, Speed Tech Torque Arm, Build Thread
Instagram @jimmysean69
The Following User Says Thank You to Jimmy Sean For This Useful Post:
syborg tt (01-21-2022)
  #1160
Old 01-21-2022, 07:46 PM
SSLance's Avatar
The nuts we tried to weld to the stud were so small they melted down before the weld would burn into the stud
Turns out, several drill bits and an easy out with assist from blue wrench was the answer.
New bolt procured and ready to put all back together now.
Lance
The Following 4 Users Say Thank You to SSLance For This Useful Post:
camcojb (01-21-2022), jarhead (01-25-2022), mfain (01-22-2022), syborg tt (01-22-2022)
