Old 08-02-2016, 11:40 AM
takid455 takid455 is offline
Larger custom made radiator and true serpentine system. Replumbed some fluid transport lines and moving along on my own EFI system. changed some other minor things that escape my mind at the moment as well.
Old 08-02-2016, 06:54 PM
Centerforce's Avatar
Centerforce Centerforce is offline
Props to you for committing to this build no matter how long it took! It came out spectacular! How are you liking the Dual-Friction clutch so far?
Old 08-03-2016, 07:43 AM
I have used the DF series clutches in several applications with no issues. The 12" was sorta new to the market when I inquired about it per what I recall when I spoke with one of your reps years ago. Haven't had any issues to speak of. The hydraulic setup makes it a lot easier to disengage vs the mechanical setup I run in another car.
Have pondered going to a dual disc when this one wears out just to see the difference.
Old 08-03-2016, 11:39 AM
Sounds good. EFI will be nice to see on a Pontiac motor.
Old 08-03-2016, 06:46 PM
We're glad to hear that. The DF is a great clutch and is perfect for 95% of modified street cars. The DYAD dual disk will give an even lighter pedal pressure, and can hold upwards of 1300 crank ft/lbs! Since it uses organic friction material, it is very mellow to drive on the street as far as engagement, too.
Old 08-07-2016, 08:30 PM
Terryd's Avatar
Terryd Terryd is offline
Inspiring build to say the least! Starting on my '72 now. So nice to see that Poncho engine in there! Great job.
Terryd
Check out the latest project at:
http://www.67novaproject.blogspot.com/
'67 Nova SS clone PT
'06 Z06 - Sold
'72 Trans Am - sold
‘73 Trans Am - Poncho Powered PT build
Old 04-01-2021, 06:43 AM
Default New EFI / engine management system
Been about a year since I got my Pontiac 24x EFI , Coil near plug system running & on the road. Aside from some expect tuning bits initially, it has performed flawless. My old TBI setup doesn't hold a candle to this. I made extra sets for my other cars & for others. I use an 0411 GM ECU but others can also be utilized. Its wonderful being able to datalog all the parameters of the old Poncho engine & fine tune. Overall the car/ engine feels more livelier & more responsive even compared to well tuned carb & TBI setups.
Here's a short video of it running on the car.
https://www.youtube.com/watch?v=vhTHRymPSlM
One might say, why this over say a Holley system.
1) Holley ticked me off years ago in this area , not the worker's fault, corporate.
2) You can obtain any of the sensors at a locale parts store if needed.
3) Anyone that can tune GM (or ECU of choice) can hook up to this via ODB2 port
4) "Why not LS/LT swap?" - Pure personal preference. Its the best of both worlds. Old school looks & feel with modern tech & reliability.
Old 04-01-2021, 07:34 AM
Sounds great and still looks great! Glad you got it working well for you.
Old 04-01-2021, 09:13 AM
T_Raven's Avatar
T_Raven T_Raven is offline
I've been wanting to try this for a long time on either one of my Pontiac or Olds engines. It's cool to see someone do it.
67, 68, 69 & 72 Firebirds, 79 TA, 89 GTA, 01 WS6, 68 Camaro, 68 Mustang, 54 GMC awd turbo, 67 GMC
Old 04-02-2021, 10:31 PM
Its a very rewarding adventure. More than pleased with the outcome. Now I need to market the setup. Might do Olds next.
Sent from my LG-G710 using Tapatalk
The Following User Says Thank You to takid455 For This Useful Post:
REZ62 (04-03-2021)
