Closed Thread
Old 09-07-2009, 07:45 PM
Love the brakes!
Hey -- in the beginning of this post - your car is shown with some "tubs" on the ground in one of the pics ... then later on you show building your own... What happened to cause that?
Still love those Forgiatos! :>)
  #112
Old 09-07-2009, 08:31 PM
Nice.....do yourself a favor and make sure you don't have a brake pad knock back issue on the rear end. You will need a dial indicator and must remove the brake pads. I don't know if the issue has been resolved with the axle retainer that wilwood provides yet or not? Now is the time to deal with it if there is a problem.
  #113
Old 09-07-2009, 08:35 PM
camaro2nv's Avatar
camaro2nv camaro2nv is offline
Love the brakes!
I ended up going with the Morrison rear clip. With the new rails I wanted something that would butt up to the rails, cleaner look. I cant get that with the DSE tubs. Im also running a 345 rear tire. I need all the room I can get! The goal is to weld the new tubbs to the rails and grind smooth. Then finish them out and paint the underside the body color.
  #114
Old 09-07-2009, 08:37 PM
camaro2nv's Avatar
Hmm should I just use the one Morrison sent? Its thicker. Nothing is set as of yet. This is just mock up.
  #115
Old 09-07-2009, 08:49 PM
Ah ha.... makes sense!!
  #116
Old 09-07-2009, 09:28 PM
Are they specifically for a wilwood setup? I tweaked one of my wilwood retainers a hair. I ended up with a set of currie retainers that go all the way around the bearing. On mine you could see the bearing move away from the retaining clip with your bare eyes! I had over .020 on both sides. I was able to get it down to .005 and .006 with the currie plates. Do yourself a favor an measure it now while it's mocked up. Wilwood was working on a new design when I talked to them 2 months ago. The new design was shimmable.
  #117
Old 09-07-2009, 09:29 PM
70rs's Avatar
70rs 70rs is offline
Wow! Monster brakes!! Looking great Steve! I must have missed it, but what is the final color going to be?
Is the baby letting YOU sleep yet??
Just wait. Someday she will be changing your diapers and loosing sleep taking care of you. What goes around comes around.
  #118
Old 09-07-2009, 10:05 PM
camaro2nv's Avatar
Will do, thanks for the info!
Ok Ok so I could wait, I had to put a wheel on. I did a little sanding, not much and it slipped on. My axle if off but I wanted to get a wheel on,lol
  #119
Old 09-07-2009, 10:08 PM
camaro2nv's Avatar
Man I keep changing the color. Im not going to say anymore until I get close paint because I keep on changing it.
Little bit of sleep, but not much. Man I cant wait to get 7 hours sleep again.
  #120
Old 09-07-2009, 10:31 PM
70rs's Avatar
I understand about the color thing. I am bouncing around a little too. But there is a lot to do before that needs to be decided.
That wheel looks great on there!
Closed Thread
