Old 10-08-2012, 02:01 PM
Steve68 Steve68 is offline
so, you got the valves right, and everythings OK?? been driving it??
Old 10-09-2012, 07:33 AM
68firebird's Avatar
68firebird 68firebird is offline
there is a small hesitation if I get on the throttle hard from idle, might be timing or carb issue, I've been fighting that for a while, and I think I need to have the alignment double checked, but everything else seems pretty good. I drove it a bit around the neighborhood this weekend (I was on watch my child duty this weekend haha). Was gonna take it to work today, but of course 60% chance of rain all day. maybe tomorrow.
Rene P.
my 68 firebird low budget build----> https://lateral-g.net/forums/showthread.php4?t=26675
Old 10-17-2012, 12:49 PM
68firebird's Avatar
Please help!!!! brake problems.
I've got LS1 brakes on the front of my firebird, I've got a new disc/drum master and prop valve, I have finally taken the car for a few rides and the front brakes stay locked, its happened the last 2 times I've taken the car out. I THINK that the calipers release after the car sits. It did it to me on friday night, sat all weekend till today and it did it again, raised the front of the car and can't spin either wheel. the back wheels seem to spin freely. any ideas?
Rene P.
Old 10-17-2012, 02:53 PM
geberhard's Avatar
geberhard geberhard is offline
Rene,
Are you using a prop valve or anything? Did you do ls all arond? Also did you use any spacers on the front or just flat plates to mount the caliper? Any pictures? Are the rear brakes locking when tires are lifted and spun by hand and brakes pressed?
Gui
Old 10-17-2012, 05:31 PM
68firebird's Avatar
Originally Posted by geberhard View Post
Rene,
Gui
yes I'm using prop valve, both master and prop valve are made for disc/drum setup. rear has stock drums. no spacers on the front, just the flat plates. the rear brakes are not locking while the front are. as far as the rear spinning while the brakes are pressed, can't try the just yet, need a helper for that.
Rene P.
Old 10-17-2012, 05:52 PM
geberhard's Avatar
rene, any way to lift the rear (safelly!!!) and drive then press brakes?
It could be residual or prop valve issue. I would gut or disconnect and see if that is the problem.
What MC are you using?
Old 10-18-2012, 04:24 AM
68firebird's Avatar
This is what I'm using.
http://www.performanceonline.com/Dis...lve-Kit-18817/
Rene P.
Old 10-18-2012, 08:59 AM
geberhard's Avatar
Rene, have you tried just unbolting slightly the two bolts holding the MCto the firewall to see if your push rod is making too much contact with the MC? May be a simple troubleshoot approach, but I know on a 67 vert I had, when swapped the MC (supposedly same part number), the MC piston surface was closer to the rod.
Was hard to tell but the push rod was engaging the MC enough. I removd, adjusted the pushrod length turning it, and problem resolved.
Gui
Old 10-22-2012, 05:46 AM
68firebird's Avatar
I haven't worked on the brakes at all since my question Gui, but since I've received many responses stating that the pushrod length is too long, thats what I'll assume it is at the moment. The reason I haven't checked on it is she is most likely in the garage now for the winter and I'm now thinking about putting a booster in.
If I put a booster in what size, 9 inch, 11 inch, does it matter? anything that I need to do to change over to the power booster or simply hook the booster in between and hood a vacuum hose up? any info would be greatly appreciated, and if you have any links to a recommended booster please post. thank you.
Rene P.
Old 10-22-2012, 09:59 AM
geberhard's Avatar
Rene, one more area to check;do you have pics of your caliper mounting bracket for the fornt? Please note a LOT of people (including myself) bought wrong brackets and that wa spart of the issue. Some adapter brackets sell as LS (Camaro\Firebird) swap brackets when they are Corvette (C5) brackets. The caliper swill work, however the rotor and contact patch will be off.
Gui
