Closed Thread
Old 11-15-2012, 02:43 PM
force-fed-snake's Avatar
force-fed-snake force-fed-snake is offline
I mainly just lurk on this site and very seldom post, but i read through this whole thread, you asked for opinions about making the body removable and I will give you mine...
without the factory floor and firewall, that relys on the rockers and whatever sheetmetal floor along with the "t" section of the roof to hold the car together. As factory designed these cars are full of squeaks and rattles as they age, doors dont fit right.. etc.
the full frame with the body actually tied into it making it a true unibody is by far gonna be the strongest platform... especially with the kind of power you're putting through it.
after a few years of having fun, i would put money on it starting to have issues if the body were to not be "one" with the chassis.
I didnt quite understand the reasoning for the motor to be set back that far, but number one, its a car. you have to be able to work on it. the dist being under the cowl just looks like a nightmare all the way around.
IF this was my project, I would tie the subframes together with material matching whats there. id cut off all of the round tube motor mounts and move it back to a semi normal place. build the floor and tie it straight to the chassis, and a flat sheetmetal floor isnt gonna do much without proper bracing and support. it can still be both functional and visually pleasing with some forethought (go back and look at the war camaro thread)
by all means I would do all of what I could on my own. without paying a shop to fix it, that leaves some money for tools, and some practice runs on scraps before doin the final parts. most of what is done to build these cars is thinking through the details and then execution.
oh, and the body doesnt have to be removable to powdercoat the chassis. I have a hot rod project goin on that I intend to powdercoat basically the whole car except the outside sheetmetal. all it takes is a big enough oven and a way to support it and get to everything.
again, these are just my own opinions, i'm not an expert. I build my own stuff for me, and I would rather push my limits and expand what I can do while having fun doing it than pay a shop to do what they do. but for me its all about the build, the creation, the fun after the fact is just a bonus (usually the project gets sold shortly after completion to fund the next one around my place)
  #112
Old 11-16-2012, 09:54 AM
syborg tt's Avatar
I agree with Force-Fed
marty-mj
  #113
Old 11-18-2012, 07:28 AM
Doug1's Avatar
Doug1 Doug1 is offline
Appreciate the recommendations guys! You make a lot of good points.
After meeting with a highly reommended local fabricator yesterday and spending several hours pouring over the car pondering the possibiilties, I think we have licked most of the technical problems with making the body removable. Not worried about flex in this car with the chassis that is underneath it.
So the chassis and body will seperate. Now as far as leaving the engine in it's current setback position... That is still under full consideration. I'm going to get with AME to see just what the pros and cons are from their perspective.
  #114
Old 11-18-2012, 07:48 AM
I just think you should ask the Mods to modify the title of this thread...
Maybe call it "My car was Fletchered"?
But seriously now that it was "Fletchered" (a new verb?) -- it should have a new title so he's not getting "credit" for having done a bunch of work that all needs to be redone?
  #115
Old 11-18-2012, 08:07 AM
camcojb camcojb is offline
I think you'd really want to start a new thread, since Chad started this thread.
  #116
Old 11-18-2012, 01:07 PM
transam's Avatar
transam transam is offline
Sorry to see this car not yet completed , i was hoping to see more second gens given the pt treatment. I hope you finally get the car you wanted. I think the best thing to do is sit back and carefully decide how to proceed, ive been in this situation and its dificult to think rationally. Best of luck!
  #117
Old 11-18-2012, 01:13 PM
Shutting this one down as the thread is being continued here:
https://lateral-g.net/forums/showthread.php4?t=39175
Closed Thread
