Old 06-30-2015, 08:41 PM
Here are the headers all freshly welded up. I gave up on trying to mig the tubes and just took them to Scotty Seals at Pro Chassis over in Hiram, GA. He routinely builds custom headers for blown mustangs so he knows what he's doing. He tigged them up for me and put the bullets on the ends of the pipes. I've installed them as you see them so I could make sure they do fit without hitting anything. I did end up having to take off the lower control arm brace on the driver's side. I'll come up with some other means to triangulate that piece probably when I pull the motor in the future.
I'm very happy with how they fit. Only 3 or 4 plugs are a pain to get to but I bought a shorty spark plug socket since I couldn't make my own that really helps make life easier. If you can find a spark plug socket that has the hex cut to the bottom of the socket, you can simply cut it down and drill out the center section to make shorty socket. The ceramic of the plug will stick through the socket after you drill it out.
All in all, these headers are easier to install than the headers I put on this engine when it was still in my 4th gen. Plug changes are easier too even with the hard ones. I can't get a decent picture of the passenger side since it's so tight in that area. Something I was able to pull off is the headers are mirror images of each other coming out of the cylinder heads. They obviously change drastically after that but from the top they look the same.
Ground clearance is great! I promise, the system is fully installed in this picture
See? There are the mufflers. I painted everything black to hide it all away.
Here's the collectors sitting up front and a view from the front. They are just under 4 inches off the ground, no lower than the oil pan, and above the front cross member still.
The mufflers are 5 inches off the ground now. I plan to lower the car in the rear some more. I should have the mufflers between 3.5 and 4 inches off the ground when done. I really hope that's plenty of clearance for me to get in and out of the driveway easily. Right now, it's a breeze getting in and out. I wish I had taken measurements before I cut the old system out, but I missed the reminder I had left myself. Oh well, I know it's more clearance. I just don't know how much.
I didn't get a good picture of it but I put v-band clamps in the system just after they turn up from the mufflers. I can easily drop the system off of the car in a few minutes. The exhaust is a slip fit with a band clamp at the collector. Best design I have ever used. I have no idea why companies still use flanges any more. I won't if I can ever help it.
Next is pulling the headers right back off to have them sand blasted and ceramic coated. I'll be going black to hide any fabrication marks. I'll also be getting the new rear in and getting the rear springs dearched. I really hope that doesn't take long. After that, who knows. I really need to get better seats and seat belts.
The Following 2 Users Say Thank You to WSSix For This Useful Post:
Brianstanford (09-27-2020), syborg tt (12-27-2020)
  #112
Old 07-01-2015, 05:27 AM
jarhead's Avatar
jarhead jarhead is offline
Really nice work Trey!
Joe
joe
Semper Fi
My 68 Torino
Old 07-01-2015, 06:50 AM
Ron in SoCal's Avatar
Joe
Ditto! Cheers Trey,
Ron in SoCal
69 Camaro in progress
Old 07-01-2015, 08:50 AM
Panteracer's Avatar
Panteracer Panteracer is offline
Default Panty Dropper
Trey cool job
Wish I had that much clearance
Bob
Old 07-01-2015, 09:38 AM
SSLance's Avatar
SSLance SSLance is offline
Heck yeah, nice work. Love how the whole system is tucked up safely away.
I want to hear a video of the exhaust...anyone else?
Lance
Old 07-01-2015, 05:47 PM
glassman's Avatar
glassman glassman is offline
Sweet!! Means you can come down another inch FTW!!!
Headers look great.
Mike
Old 07-01-2015, 06:15 PM
That's the plan, Mike. I was able to find a place that can de-arch the springs so I'll be dropping it in the rear soon. What are you ground clearance numbers with the Hooker headers?
I'm going to try to get a sound clip, Lance. Not sure how but we'll see. I failed to mention that I was able to get all the primaries to be close in length. If I remember correctly, the shortest is 27 to 28 inches and the longest is around 34 inches. That's between all tubes on both sides. They are all within four inches of each other per side though. There's also an x-pipe under the car. I started with a Pypes system without mufflers and then made it fit the car with my home made parts. I think this all contributes to the smooth note. I could be completely wrong though.
Thanks everyone! I appreciate the kind words.
  #118
Old 07-01-2015, 07:35 PM
Che70velle's Avatar
Trey, excellent work! Those look great. How much lead time do you need, when I'm ready to have you build me a set?
Looking forward to hearing sound clip!
Thanks Dad!!
Old 07-01-2015, 07:44 PM
lol, you ready to be without your car for another 6 months? It's a challenge to do them right. I know I'm well over 100 hours into these. Granted, most of that was me simply not knowing what I'm doing. I can see myself building another set in the future, but it will be on a car that's in the build stages and not one that was driving and being upgraded like mine.
Thanks Scott
EDIT: C&O is this weekend. I'll drive the car this instead of ride the bike. Headers will come back out after the show.
  #120
Old 07-01-2015, 08:56 PM
Excellent Job!
