Old 08-18-2016, 11:16 AM
He needs to update this thread. He's put some miles on this car since the last update.
Texas A&M BSME 2008
1969 Camaro - Hugger Orange
1969 C10 SWB - Hugger Orange
1992 Corvette ZR-1
2021 Ford F250 Tremor
Old 08-18-2016, 02:10 PM
Nine Ball Nine Ball is offline
Originally Posted by dhutton View Post
Did you get the convertible top installed? I am trying to decide if I should minitub my 69 convertible.
Don
I installed the vert roof frame and fabric myself. Not difficult, but very time consuming. It required a lot of patience, since you have to keep making adjustments over and over and over again. I'll update the thread, car is done now (since June).
Founder, LS1Tech.com
1969 Camaro SS Convertible | 1970 Chevelle SS 454 | 2006 Viper Coupe | 2014 Viper TA | 2014 Camaro SS 1LE
Online Garage: www.fquick.com/NineBall
Old 08-18-2016, 02:49 PM
dhutton dhutton is offline
How did the frame fit with the minitubs. I remember you said it would need some reshaping of the tub. Could you post a pic?
Thanks,
Don
Old 08-18-2016, 03:01 PM
D-$ D-$ is offline
Thanks,
Don
x2 I also am very interested.
Old 08-18-2016, 03:27 PM
Thanks,
Don
The tops of each wheel tub needed some "persuasion" via the tip of a ball-peen hammer. I know I took some pics of it, but will have to dig them up. There is only the lower bar that contacts the top of the wheel tubs (even the OEM wheel tub flange is hammered over). It was easy, just fold the frame down and trace an outline of where the frame contacts the top of the wheel tub. Push frame out of the way, then hammer the marked area down. You can do a little at a time. Probably not even a 1/4" deep in the worst areas. once you get the lower frame to go down without touching anything, you will know it is done.
Old 08-18-2016, 03:39 PM
Thanks Tony.
