Old 11-30-2015, 07:34 PM
V8TV's Avatar
V8TV V8TV is offline
Default ZR9 Camaro - An 804 HP LS7 / LS9 Powered New 1969 Camaro at V8 Speed & Resto
We build lots of Camaros in the V8 Speed & Resto Shop, and each is different and unique.
This is an interesting car for many reasons, beyond the 800+ HP Mast Motorsports supercharged engine. We're using a new Dynacorn body on this one that we bought from Classic Industries, so the entire car will be new. The owner had no real attachment to a particular car, he just wanted a Camaro.
Here's the Carter Hickman Designs rendering:
This car will be riding on [url=http://www.detriotspeed.com]Detroit Speed & Engineering front suspension and subframe, with their QUADRALink rear suspension.
This is how the Dynacorn body arrives:
Looks pretty good at first glance. We'll get into the panel fitment later, but we noticed some of the resistance spot-welds were off a little, but even GM was guilty of that. Be prepared to address this kind of thing if you work on one of these.
Kevin Oeste
V8 Speed and Resto Shop
V8TV
Muscle Car Of The Week
V8 Radio Podcast
All about us:
https://www.v8speedshop.com
Old 11-30-2015, 07:38 PM
V8TV's Avatar
The deck lid, doors, and quarters all seem to fit much better on this one than they did when these reproduction bodies first hit the market. They appear to have a factory style fit, but we'll be tuning that up on ours.
The wheel tubs appear stock, but the wheel lips are in need of some attention regarding the placement and tidiness of the spotwelds.
The rear frame rails and floors all look correct.
Kevin Oeste
V8TV
V8 Radio Podcast
All about us:
Old 11-30-2015, 07:39 PM
V8TV's Avatar
We noticed a nice, straight lower door to rocker fitment.
The deck lid gap appears a little inconstant, but not completely off base.
Deck to quarter gap is a little wobbly, and the quarter panel came with a dent in the contour line.
The rear window filler panel fit is OK, we'll weld this up to prevent it shifting in the future.
The tail pan looks like many of the reproduction pieces, but the lines are a little more defined than many. The tail light openings can be hit or miss on the repro panels, but these look better than most.
Kevin Oeste
V8TV
V8 Radio Podcast
All about us:
Old 11-30-2015, 07:55 PM
DOOM's Avatar
DOOM DOOM is offline
Kevin I'll be watching this one! We have one Lateral member that had to give up on his Dynacorn body I know this won't be the case here!!!!! Keep the updates coming.
Mario
USCOLLISION
Old 11-30-2015, 07:59 PM
V8TV's Avatar
That's a bummer. This one had a few ups and downs, but the story has a happy ending. We'll post it all.
Thanks!
Kevin Oeste
V8TV
V8 Radio Podcast
All about us:
Old 12-01-2015, 12:12 PM
Jay Hilliard's Avatar
Very cool Kevin. Looking forward to seeing the progress and pics.
Jay
Old 12-01-2015, 06:16 PM
syborg tt's Avatar
Subscribed
Marty-MJ
www.garagescene.net
marty-mj
Old 12-01-2015, 06:46 PM
V8TV's Avatar
Subscribed
Marty-MJ
www.garagescene.net
Welcome Marty! Kelle enjoyed chatting with you at MCACN, sorry I was running around quite a bit that weekend to catch up, but she brought me up to speed. We both hope all goes well for you and your family!
Kevin Oeste
V8TV
V8 Radio Podcast
All about us:
Old 12-01-2015, 06:47 PM
V8TV's Avatar
Our plans for this car call for "spirited" driving courtesy of the 800+ horsepower Mast engine, so we'll need to run much larger tires than the stock Camaro wheel tubs can hold. The solution is the install of some Detroit Speed deep tubs. First, Eric cuts out the stock rear trunk hinge support by drilling out the stock spot welds.
Next, the wheel tub spot welds are drilled. Note the line on the floor, this is where the floor will be cut and folded to accommodate the deep tubs.
Behind the wheel tub, the white line is cut in the trunk floor to house the deep tub.
The frame rail before modifications.
Kevin Oeste
V8TV
V8 Radio Podcast
All about us:
Old 12-01-2015, 06:48 PM
V8TV's Avatar
The frame rail is notched and narrowed, and a heavy plate is formed and welded in place to add increased strength.
The new DSE deep tub is clamped into position and fitted to the car.
The lower portion of the tub is punched with holes for plug-welding, and then the whole tub is welded in place.
Looks like the wide rubber will squeeze right in!
Kevin Oeste
V8TV
V8 Radio Podcast
All about us:
