Old 11-05-2023, 05:11 PM
Cramer4918's Avatar
Cramer4918 Cramer4918 is offline
I bought some stainless wire for my welder and was able to get the pieces tacked together. I know it’s not pretty, but I’m working with minimal tools.
My plan is to make the exhaust in three sections. I will use stainless clamps to join the sections together so that I can remove them if needed. I am going to take the sections to get TIG’d together.
I know the tacks are bigger than needed. I’m still learning to weld properly. The guy that is going to TIG the pieces together said he can work with them. I am hoping to be able to watch him and I will possibly grind some of the tacks down as he gets some solid welds in.
Not too shabby for my first time building an exhaust.
I just need to commit to either side exit or all the way out the back now.
-Matt-
'61 Biscayne ~ AKA BISKWIK
The Following User Says Thank You to Cramer4918 For This Useful Post:
Goosesdad (11-07-2023)
  #112
Old 11-05-2023, 06:00 PM
Cramer4918's Avatar
In the middle of getting the exhaust mocked up, my new to me injectors arrived. I did some research on the ones that were installed and found out they were only 24# injectors. They may have worked for my application, but they would have been maxed out in duty cycle according to the flow calculator I used. The new injectors are 50# GM injectors. These will be more than adequate for my setup.
The injectors that were installed when I got BISKWIK.
The 50# injectors with EV1 to EV6 adapters and injector spacers in place.
Hopefully I’ll be firing it up soon!!!
-Matt-
The Following 3 Users Say Thank You to Cramer4918 For This Useful Post:
Che70velle (11-09-2023), Goosesdad (11-07-2023), Roscoe03 (11-14-2023)
  #113
Old 01-04-2024, 06:06 PM
Cramer4918's Avatar
Happy New Year Everyone! I hope you all had a Great Christmas and great New Year!
A small update for BISKWIK. I didn’t work on it much while the kids were out of school, but I was able to make some progress.
Passenger side exhaust ran to the back.
Decent clearance for the tires. I am running 285/35’s on a 20X9 wheel.
I need to make turndown for the mufflers still.
-Matt-
Old 01-04-2024, 06:11 PM
Cramer4918's Avatar
I managed to finish the driver’s side as well.
I had to order two 30 degree elbows to finish this side. A minor four day setback.
Not too shabby for my first time building an exhaust. I have to get hangers in place and then I’ll take it all off to get TIG welded. I am hoping g to have it all back on the car 100% by next weekend. We shall see.
-Matt-
The Following 2 Users Say Thank You to Cramer4918 For This Useful Post:
Roscoe03 (01-14-2024), srode1 (01-18-2024)
  #115
Old 01-04-2024, 06:25 PM
Cramer4918's Avatar
The journey for cutting the tubing was painful in the beginning. Making clean cuts on the pipe was challenging with a 6” angle grinder. Not to mention, getting the tubing cut square on the bends. Initially I wrapped painters tape around the tubing and marked them that way. Most of the time I would end up making adjustments to my cuts to get the ends to mate up properly. That was time consuming to the say the least. I then discovered the technique of using a zip tie cinched down around the tubing. You could move it however you needed along the elbow and mark it. That allowed me to get the my cuts marked perfect every time!
It was like magic!
Another trick I learned was to use a tubing cutter. I found one that would cut up to 2 5/8” on Amazon.
https://www.amazon.com/ICOOL-Tubing-.../dp/B0868G4BDK
It helped make the cuts perfect every time! It was a little difficult once the elbow got tighter, but it worked on the 30 degree elbows with no problem. I’ll see if I have any pics of that.
Hopefully that info helps whoever would want to tackle their own exhaust.
-Matt-
The Following 4 Users Say Thank You to Cramer4918 For This Useful Post:
68454RS (01-05-2024), camcojb (01-05-2024), jarhead (01-07-2024), Roscoe03 (01-14-2024)
  #116
Old 01-13-2024, 04:00 PM
I used the ziptie trick with the headers and exhaust on the TA. Worked great as you've seen. Your exhaust looks great.
Side note, I had no idea Flowmaster made a straight through style muffler like Magnaflow until I was hunting for exhaust for my C10. I wanted low buck because I'm cheap. I love Magnaflow but found the Flow FX mufflers for half as much. Hopefully, I like the sound.
Keep up the great work.
Cramer4918 (01-14-2024)
  #117
Old 01-14-2024, 06:52 AM
Cramer4918's Avatar
Thank you for the compliment! I do appreciate it!
I definitely learned a lot during this process. I am hoping to improve my welding skills for future projects.
I like the Magnaflow mufflers as well. I am hoping these Flowmasters sound as good as them. They appear to be the same internal construction. Once I get it running, I’ll try to post a sound clip.
-Matt-
WSSix (01-15-2024)
  #118
Old 01-16-2024, 05:49 PM
Cramer4918's Avatar
Unfortunately, the flat bar I purchased was zinc coated, so I could not tack it to the exhaust with my setup.
Prior to realizing that, I made up a hanger. I made up a jig to bend the bar to curve round the pipe. I heated the bar up and then used a hammer to form it. I guess one of my next purchases will be a vise.
I planned on using grommets and rivnuts to secure the exhaust.
Using the tools and items I had available to me, it took almost an hour to make this one bracket and install the rivnut. All a waste since I can’t weld it to my exhaust. I have stainless flat bar ordered now.
-Matt-
camcojb (01-16-2024), Roscoe03 (01-18-2024)
  #119
Old 01-16-2024, 05:53 PM
Cramer4918's Avatar
The flat bar arrived today, but I am at the Fire Department and I am supposed to get the exhaust TIG’d up on Thursday.
I will have to take it back once I get the brackets made up to TIG those on as well.
Exhaust pulled out from under BISKWIK.
Pretty symmetrical for the most part. Not bad for my first time!
Loaded up and ready for Thursday
-Matt-
  #120
Old 01-17-2024, 06:03 AM
ScotI ScotI is offline
It's hard to tell from the images.... What material is the tubing you used?
*EDIT*
Found my answer in post #111. I think you'll want to make sure the 'hangers' used allow for some fore/aft shift as SS likes to 'grow' when it gets hot. Certain sections will see higher heat vs others so allowing movement seems to keep things happy. Just my experience/s w/the material.
The Following 3 Users Say Thank You to ScotI For This Useful Post:
camcojb (01-17-2024), Cramer4918 (01-19-2024), Roscoe03 (01-18-2024)
